think my truck is defueling
Old May 4, 2010 | 08:38 AM
redneck817's Avatar
Default think my truck is defueling
if my truck sits over night it takes three or four attemps to start before she even acts like she is gettin fuel, i know i need to replace glow plugs on her. would a return line kit fix problem? and what is a good power steering pump to use
Old May 4, 2010 | 12:33 PM
cowboyford16's Avatar
injector's injector pump, or lift pump
Old May 7, 2010 | 09:03 AM
green thang's Avatar
i got the same problem with mine i think it might be a injector pump. is there any way to test some of this stuff before i go blow 500 on a new ip pump? or god knows what else might it be?
Old May 7, 2010 | 12:58 PM
Sycostang67's Avatar
If the truck runs fine when it's going, then I doubt it's an IP problem. Air intrusion and bad glow plugs are the most typical causes of hard cold starting. Check your return lines and hose connections for leakage, make sure your fuel filter is still tight. If you know the plugs are bad then change them out for some motorcraft plugs.
Old May 7, 2010 | 07:05 PM
redneck817's Avatar
well i know i got to replace the gp's and think airmight be gettin in through my filter not to sure but i know there isnt any fuel anywhere else on the motor
Old May 8, 2010 | 02:34 AM
I know that when I had 2 dead glow plugs, it could take 2-3 tries to get my truck started.
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
