Has anyone softer the rear leafs?
Old May 3, 2010 | 06:24 PM
Turbohunter's Avatar
Default Has anyone softer the rear leafs?
Not gonna be using the truck to pull any trailer or load at all. Wondering if anyone has soften the rear leaf springs up with others. Its time for me to replace them and I wanna see if the ride can be a little bit smoother. Its on a 2001 Dodge Ram 2500. I just hate how it bounces all over the place on a normal road. Anyone got any suggestion on how to soften the ride up?
Old May 3, 2010 | 08:09 PM
stevenbrazell's Avatar
buy a car. haha just kidding, but throw a couple bags of cement mix or dead weight over the rear axle. it'll help by starting to make the leaf packs compress and stop that preload they need to start flexing.
Old May 3, 2010 | 08:51 PM
Red_Rattler's Avatar
High Tech Redneck
Kore makes a mini pack that replaces the overload and it calms the ride a TON! Plus it still has the same carring capacity... Thats whats on my truck
Old May 4, 2010 | 07:30 PM
thanks red rattler i am gonna look into that
Old May 11, 2010 | 10:04 PM
Karls03's Avatar
I know I'm seven days late here, but have you tried a softer shock? I put an add-a-leaf on my truck and it was pretty cool with OEM shocks. Then I bumped up to a Rough Country nitrogen shock and it got REAL STIFF. A softer shock may take some of the harshness out of that ride.
Old May 11, 2010 | 10:08 PM
Benjamin's Avatar
Bombardier
i removed the overload spring on my truck. it leveled it out and allowed the suspension to actually work and transfer weight when i raced from a dig.
the downside is it made my payload go to crap but i don't care, my kidneys thank me....
Old May 12, 2010 | 12:24 PM
Nor-Cal Nick's Avatar
A set of Bilstein shocks and Sulastic shackles in the rear will help alot. It doesn't make the truck become a car but it does enough to take that edge off to make these heavy duty trucks ride way better on the open highway and city streets.
Old May 26, 2010 | 08:41 AM
harry22's Avatar
Old May 26, 2010 | 09:12 AM
theSLEEPER's Avatar
What pressures do you keep your tires? I tend to keep my rears at the minimum when unloaded...
Old May 26, 2010 | 07:50 PM
7.3 Cowboy's Avatar
if you want a soft ride buy a car
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
