power???
Old May 3, 2010 | 02:44 PM
rollincoal12valve's Avatar
Default power???
guys im looking to figure out how much power im puttin out with all my newly installed mods and what not...
they include
100 plate ff
35/40hybrid making 43lbs
stock injectors
fully tuned afc
all fuel turned up
bhaf
4 inch exhaust straight piped to 8 inch stack
hd built trans
any ideas?
i was hopin for like the 350ish range and about 800 foot pounds
i was thinkin about a set of stage two pensacola injectors and then some twins later on
Last edited by rollincoal12valve; May 3, 2010 at 02:44 PM. Reason: Automerged Doublepost
Old May 3, 2010 | 03:05 PM
cumminspwr11's Avatar
i believe the 100 plate alone ups you around 100hp in the center of the pump, im running the stage 2 injectors form pensacola in my truck and they were a good upgrade for the money. i used to be right around 43lbs of boost but it has dropped to around 38 i may have some leaks, anyone ever cracked an intercooler?
Old May 3, 2010 | 06:12 PM
oglejust's Avatar
ur probably around 300hp, put in a rack plug which is like 20 bux shipped and that'll help too. also idk wat u mean by fully tuned but u need 2 do the washer flip and grind the barrel on the aneroid arm if u havent already
Old May 4, 2010 | 07:13 PM
thats what i meant by fully tuned afc haha
and what would you guys reccomend to pick up some power besides the rack plug i heard that is a pain in the ***
Old May 4, 2010 | 07:39 PM
the rack plug isnt to bad, i used a dremel with a high speed cutting bit, it cut the timing cover like butter, once the stock one is out use a few screw drivers to hold it in place while you get the threads started. i would also find some used 181 dvs and swapped them with your 131s. 3k or 4k govenor springs would also bring make a big differnce.
Old May 4, 2010 | 09:37 PM
def trying to get a set of gov springs but other than that i think im gettin plenty of fuel because my hybrid cant even clear all the smoke up with 43 pounds of boost im runnin like 1200 on flat ground and 1500+ uphill i was thinkin bump the timing or a bigger turbo or even twins but i dont know what my tolerances are with head gaskets and other internals to what they can handle...
also i am trying to figure out what kind turbo to pair up with my hybrid or my old hx35 that has about 8000 miles on it what would you guys reccomend???
Old May 4, 2010 | 09:54 PM
94 12valve's Avatar
ht3b with a small exhaust housing would work well.
Go with the 4k springs right off the bat, the 3ks are really not worth it IMO
Old May 4, 2010 | 10:26 PM
can stock heads and valve springs handle 4k? i dont have much experince with those ones but i heard somewhere the pistons may hit the valves??? correct me if im wrong
whats the opinion on the adjustible govenor spring kits are they worth it?
your stock head is at its limits around 45lbs of boost, i wouldnt go much over that without studs
Old May 4, 2010 | 10:55 PM
lodal cummins's Avatar
i was told today not to go with the 4k with my stock head set up. i have the 3k and like it but the 4k fuel alot harder. i got some 75hp new injectors and really wanted to go with the extra small spring to make it 4k. but the pro's at the shop highly advised againts it until upgrading my head set up. just my 2 cents
Old May 4, 2010 | 11:05 PM
12vcummins96's Avatar
get the valve springs and do a 4k kit
