torque spec. for LB7
Old Apr 29, 2010 | 09:26 AM
2500hdbduke's Avatar
Default torque spec. for LB7
I was wondering if someone had the torque spec..For the valve cover bolts and the injector
hold down bolts and the return fuel line bolts.
Thanks 2500hdbad
Old Apr 29, 2010 | 07:46 PM
gbhrps's Avatar
This is the answer that I got for the same question I asked on the Diesel Place LB7 Forum in the last week or so:
Gene
Tighten the injector hold down bolts to 37 ft lbs.
Tighten the return line banjo bolts to 12 Nm or 106 lbin. Tighten the 12mm banjo bolt that goes into the head to 11 lb ft
Tighten the lower valve cover bolts in sequence to 10Nm 89 lbin twice
Tighten the injector harness bracket bolts to 9 Nm or 80 lbin
7mm connectors to 2Nm or 18 lbin
Tighten the upper valve cover bolts to 8 Nm or 71 lbin in.
For more info go to this link.
http://www.duramaxforum.com/forum/ho...-pictures.html
Hope this helps! - Titus
__________________
Truck: 2001 Chevrolet 2500HD Duramax/Allison Crew Cab
Royal Utility bed and racks
242,000 Miles :o Tuner: PPE Standard on level 2.
Turbo: Stock, PPE boost valve, Modded Intake Horn
Suspension: Firestone Air Bags, Dual air horns behind the grill Exterior: Spray in bed liner, Bedslide (roll out bed), Convert-A-Ball Hitch,
Mods: High idle, All headlight on, Cab lights, HID Fogs in the mail
Interior: Sunpro Mech. boost and EGT gauges :gearjamin
Da Bomb
Sep 3, 2015 10:00 AM
Jun 22, 2015 12:40 PM
Mar 26, 2015 08:10 AM
Dec 27, 2014 03:00 AM
Gizmo52
Oct 1, 2014 02:13 PM
