Coolant in air filter
Old Apr 28, 2010 | 06:01 PM
dj0443's Avatar
Default Coolant in air filter
Went to change air filter and found it soaked with antifreeze.Is this a sign of a blown head gasket.Did a coolant bsystem pressure test and all was good.Thanks
Old Apr 28, 2010 | 06:16 PM
12vcummins96's Avatar
Default coolant in air filter
no thats a good question if you did a test and it was good then
Old Apr 28, 2010 | 09:18 PM
ArizonaRedneck's Avatar
welcome to diesel bombers dj0443 and is your overflow tank anywhere close to your air filter housing man i dont know thats definetly something different there
Old Apr 28, 2010 | 09:28 PM
dj0443's Avatar
Unhooked the air intake hose from engine.I have coolant in it to.
Old Apr 28, 2010 | 10:41 PM
how was your coolant level when you checked it
Old Jun 3, 2010 | 07:23 PM
toddster911's Avatar
the turbo cools itself with coolant, which is directly connected to the airbox and filter..maybe some sort of blowby-blowback from there?? I have seen this on modded jap 4bangers with after market turbo's
worth a look
let us know the outcome.
Old Jun 3, 2010 | 10:08 PM
tfunk22008's Avatar
i thought it was to my understanding that the turbo was only cooled by the oil that runs through it?
Old Jun 4, 2010 | 08:04 AM
I am in the midst of a FPR change and there is a coolant line that goes to the turbo.
Old Jun 8, 2010 | 09:44 PM
stevenbrazell's Avatar
saw a ford lightning at work that had the same thing. when going from high boost to none it creates a vaccum between that switch and caused oil to head back into his intercooler. dont know if this helped yall.
jeffersonl
Nov 15, 2015 07:35 PM
robbyS
Apr 16, 2015 02:22 PM
Joebritt3210
Feb 11, 2015 01:44 PM
fire1296
Feb 4, 2015 06:15 PM
jeffersonl
Oct 25, 2014 06:46 AM
