Loud Blowing Noise
Old Sep 16, 2007 | 01:15 PM
SFC Diesel's Avatar
Default Loud Blowing Noise
Last night while towing my cousins race car, my 05 dodge, started to fall on its face while pulling a hill.
now I can hear a loud blowing noise when my rpm reaches about 2,000.(it sounds like it is in the glove box.)
I pulled my S & B intake off, and checked the boots, along with the inter-cooler boots. they are all fine.
I can only get boost up to 20 psi,
any Ideas.
Old Sep 16, 2007 | 01:22 PM
Whit's Avatar
Site Mascot
you blew a boot....most likely the one from the charger discharge to the inlet of the intercooler................may also be cut and yajust cant see it
its there..heheheheheeeee been there done that
Old Sep 16, 2007 | 02:22 PM
DB Admin's Avatar
Banned
Whitmore didnt you have a way to test for leaks ?
Old Sep 16, 2007 | 06:01 PM
Uncle Bubba's Avatar
You can make a pressure tester for a couple bucks worth of PVC pipe and glue.
If I remember right it's 4" PVC that the OD on a fitting fit's right into the rubber boot at the turbo. Just loosen the boot and pull it off of the turbo side and replace it with the tester and apply air pressure.
You can use any kind of configuration you want for the tester as long as it's sealed when your done. In my case I used a 90 degree elbow, a 6 Inch nipple and a cap. Drill a hole in the cap just big enough to fit a replacement tire valve stem into it. Use JB Weld to seal the valve stem in place. This allows you to install this pipe onto your system and pressurize it to locate all leaks.
This is for a second gen truck and I assume everything works the same on the 3rd gen.
Old Sep 16, 2007 | 06:16 PM
Whit's Avatar
Site Mascot
yep........bout the same thing I did
works well and its amazing the leaks you can find when its all quiet.......the big Cummins is sleeping
Old Sep 16, 2007 | 09:34 PM
If you wanna really find all the leaks use some dish soap in a spray bottle and spray it over the entire system while it's pressurized. Any leaks will show up with bubbles just like checkin gas lines. This will find small leaks.
Old Sep 18, 2007 | 04:27 PM
SFC Diesel's Avatar
wasn't the boot, it was the whole right side of the inter cooler.
thanks for the help.
Old Sep 18, 2007 | 05:10 PM
Whit's Avatar
Site Mascot
holy cow.................and the boot held
this aint one of them new cheap *** plastic intercooler headers is it
Old Sep 18, 2007 | 05:11 PM
Either way it aint gonna be a cheap replacement. Guess that's one way to decide on a bigger aftermarket inter cooler though.
Old Sep 18, 2007 | 05:37 PM
scrappy's Avatar
even the factory replacement won''t be plastic, Dodge realized their error and quit using the plastic and are replacing the plastic ones with the aluminum ones as they blow.
