Can anyone help me out on a cummins question?
Old Apr 26, 2010 | 10:45 PM
fumminsplease's Avatar
Default Can anyone help me out on a cummins question?
Ive been looking for a 12 valve for my truck but I can olny find industrial versions. I'm wondering if it would be possible to mate a 47 rh to that engine and if anyone would happen to know where to find the dodge cummins engine at if this wasn't possible also I'm sure the motor mounts are different to.
Old Apr 26, 2010 | 11:00 PM
12vcummins96's Avatar
they will mate fine you are going to make motor mounts anyway
Old Apr 26, 2010 | 11:06 PM
my plan was get an industrial engine buy a built tranny then buy motor mounts from fordcummins, on the industrial it looks like they olny have two bolt holes for the motor mounts and the where the bell housing mounts it looks huge
Old Apr 27, 2010 | 02:45 PM
the_new_kid's Avatar
they are the same engines other than some of the turbos they came with and fuel settings everything else like the block is identical and will accept on the road cummins parts. as for the adapter plate it is prob a sae3 adapter plate tyhat you see on there and you will need to put on the adapter plate for your tranny.
Old Apr 29, 2010 | 06:41 PM
Where could a guy find the bellhousing mount for a 47rh? If my wording is incorrect I apologize I'm only a sophomore in highschool so I got a lot to learn about engines yet.
Old Apr 29, 2010 | 07:04 PM
Red_Rattler's Avatar
High Tech Redneck
Industrial as in tractor or gen set? Or industrial as in outa a bread truck or simalar on road vehicle?
Old Apr 29, 2010 | 07:09 PM
industrial as out of like a step van or bread truck with a/c and all that
Old Apr 29, 2010 | 09:17 PM
High Tech Redneck
Alright good thats a start I hope its a front geartrain motor. If its a rear then keep looking
Old Apr 30, 2010 | 07:51 AM
What do you mean front geartrain motor?
Old Apr 30, 2010 | 01:09 PM
The injector pump and all the other accesories will be driven off the back of the motor nearest where the transmission would bolt up. You want one with all the gears and stuff on the front of the motor.
