Anyone using the Nissan 6cy TD out of a UD mediun duty truck?
Old Apr 25, 2010 | 01:28 AM
FTE's Avatar
FTE
Default Anyone using the Nissan 6cy TD out of a UD mediun duty truck?
I have a line on a 92 Nissan TD with allison with low miles for cheep, was wondering if anyone has any info good or bad on weather this would be a good choice for a conversion motor. I think it is a 6.9. Havent heard too much about this motor, but the price is right, would be cool in some old iron- its huge.
Old Apr 25, 2010 | 03:11 AM
Deezel Stink3r's Avatar
Does it have the japanese license reproduction Bosch inline injection pump( Can't remember Nippon Denso or Kikki ?)
If so, it is the engine used also in the Nissan Patrol.
A very cool, bad *** engine and built to run forever!
A friend of mine uses it with a straight exhaust in his Patrol and he beats the hell out of it. But he takes care about the fluids.
Take a picture and show it- I will tell you
The IP and turbo must be on the right side.
Should be a SD 33T engine,but as the name already shows it's only a 3.3L engine with around 100hp.
Old Apr 25, 2010 | 11:17 AM
FTE's Avatar
FTE
The ip is on thr left, turbo on right, it came uot of a UD 2600 truck. I think it is a 6.9. It is way bigger than a 6bt cummins
Old Apr 25, 2010 | 11:50 AM
It should be the 456 (7.47L)Cui engine with 230hp@2500rpm and a 750rpm idle speed?
Thats a friggin' huge engine...
Have seen the smaller patrol engine in a Cherokee.
Old Apr 25, 2010 | 02:19 PM
FTE's Avatar
FTE
Yea, that sounds about right, its huge so a full sized or larger platform is what I am thinking. Maybe a 30's ,40's cabover or some frankenstine deal.
Old Apr 25, 2010 | 08:28 PM
Cbum's Avatar
I use to work for UD as well very durable engine but it has been at least 15 years since I wrenched on one .But if memory serves they were very reliable as was most of their line up.
Old Apr 26, 2010 | 12:03 AM
FTE's Avatar
FTE
Thanks for the info guys, hey Cbum, hows the Elcamino comming along?
Old Apr 26, 2010 | 07:22 AM
Cbum's Avatar
In a holding pattern till I can get caught up with a deludge of other projects and funds . But hopefully I will be setting engine in place in the next couple of weeks and cutting trans tunnel to make room for the allison
Old Apr 26, 2010 | 10:59 AM
FTE's Avatar
FTE
Cool, keep us posted!
