Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Thunder 330 Turbo
Old Apr 24, 2010 | 07:32 PM
FormerVendor
Default Thunder 330 Turbo
The Thunder 330 is Industrial Injections latest turbo creation. Fits 03 - 07 Dodge 5.9L Cummins. It is built from a BorgWarner S330. It is offered in Dodge 3rd generation configuration only. It is equipped with a 62mm compressor wheel and the proven 74mm exhaust wheel. The exhaust housing measures 14cm and is custom built. The 14cm exhaust housing comes standard with large wastegate passages built at the factory with the intention of relieving exhaust pressure in a hurry. Most turbos are equipped with a 30 lb. wastegate actuator. The Thunder 330 turbo comes standard with heavy-duty, 40 lb. wastegate actuator. The journal bearings in the Thunder 330 are larger and wider than that of a S300. This give the Thunder 330 more of a hydraulic advantage to keep the rotating assembly centered at higher boost pressures. Most S300 turbos come with a four pad thrust however, the Thunder 330 comes standard with a six pad thrust. Bottom line, the Thunder 330 is a powerfully built turbo at a great price.
Thunder 330 Turbo 03-07 Cummins
Old Jun 3, 2010 | 11:33 PM
FormerVendor
Old Jul 24, 2010 | 12:12 AM
FormerVendor
Default Re: Thunder 330 Turbo
The feedback we have got on these turbos are great. These are Genuine Borg Warner Turbos with an Industrial Injection Twist.
Luke
DieselDawgs
(828)631-1546
Old Aug 16, 2010 | 10:33 AM
FormerVendor
Old Aug 16, 2010 | 11:15 AM
bobcat67's Avatar
so do they make one of these turbos with a 64mm compressor wheel? just curious
Old Aug 16, 2010 | 06:48 PM
FormerVendor
As of right now they are only available in the 62/74/14
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
