Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Amsoil??
Old Apr 21, 2010 | 07:54 AM
DIRTYMAX2004's Avatar
Default Amsoil??
Im goin to start running Amsoil in the front and read diffs. I am wondering if i need to flush the diffs before i can start running the new oil or what.
Old Apr 21, 2010 | 03:30 PM
06Dodge's Avatar
No need to flush, just remove the cover, let it drain for an hour or so, replace cover and refill.
Old Apr 21, 2010 | 05:08 PM
Stumblefoot's Avatar
I cleaned mine out with some break cleaner just to remove any sludge, but its probably not necessary.
Old Apr 22, 2010 | 08:20 AM
Heath's Avatar
Authorized Amsoil Dealer
If it looks dirty a flush can be done but should be done with the same fluid you're putting in or another gear lube. Here's the potential problem with using chemicals to flush:
Do not use solvents to flush transmissions or differentials.
Solvents can have the following negative effects on gears
and bearings in differentials and transmissions:.
• Foaming – Residual solvent such as, chlorinated
solvents or solvent-type flushing compounds
used to wash out the gearbox may cause foaming.
• Rust – Gears, bearings and internal parts if left
dry and free of oil, can start rusting in a very
short period of time after they are washed down
with solvents.
• Viscosity Loss - The presence of even a very
small amount of solvent-type flushing compound
can reduce the viscosity of oils.
wlofton
11
Jun 26, 2018 08:58 AM
Spk329
May 23, 2015 12:46 PM
LittleBuck
23
May 21, 2015 06:06 PM
