Front and Rear Brake Job
Old Apr 19, 2010 | 07:14 PM
wildbill's Avatar
Default Front and Rear Brake Job
Any special tools needed to do the job, like a caliper compressor??
Old Apr 19, 2010 | 07:17 PM
12vcummins96's Avatar
you can use a c clamp and the used brake pad
Old Apr 19, 2010 | 07:21 PM
Whit's Avatar
Site Mascot
mke sure you dont push the old fluid bac into the resivor, ude the bleeder screw.......change the fluid too whilst yer there
I have 155k on mine and the brake pads are still 75%.........exhaust brake
Old Apr 19, 2010 | 07:23 PM
wildbill's Avatar
I'm on 106,000ish on mine, and the rears are making noise. Might as well do em all, and I won't have to resurface/replace any rotors.
Old Jun 6, 2010 | 05:29 AM
skyjacked84's Avatar
oops mine was over flowing when i used a c-clamp. how bad is that for the breaks? truck seems to stop quick
Old Jun 6, 2010 | 10:14 AM
Heres a tip - speed bleeders are worth every penny.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Old Jun 6, 2010 | 10:48 AM
UntrainedEye's Avatar
When I did mine a couple months ago, I use a piece of hose. Stuck one end on the bleeder, and the other into a jar of fluid. Made sure the hose was clamped around the bleeder.
Old Jun 7, 2010 | 08:52 PM
torqctd's Avatar
Could effect your ABS sensor. Good idea to push the fluid out through the bleeders.
shingi
Off Roading
Sep 30, 2015 11:17 AM
corksil
Jun 30, 2015 06:58 AM
dougcarlo
Oct 18, 2014 03:15 AM
