diesel leak
Old Apr 18, 2010 | 11:22 PM
Lawson's Avatar
Default diesel leak
in the past year i have replaced the valve that drains the water from the fuel filter three times, and every time i replace it it starts leaking after about a month. are others having this problem, or am i doing something wrong? and also my cruze light has quit working. i checked all the fuses and a few were blown, but when i replaced them it still doesn't work. i have not done anything about the recall on the cruze system,,, is that what it is or is it just the diode burnt out or something completly different? thanks lawson
Old Apr 19, 2010 | 10:12 AM
codiesel's Avatar
check the light bulb in the cruse controrle area and i have the same fuel problem
Old Apr 19, 2010 | 01:39 PM
Lawson's Avatar
that plastic valve isnt worth a dam... im thinking about trying to fabricate a brass valve , but i cant exactly remember what the hookup to the bowl looks like, and im afraid that if i take it off to look at it i wont be able to get it back on without causing a worse leak. i think its also leaking from the sensor plug right beside it. im guessing thats the water in fuel sensor.
Old Apr 19, 2010 | 02:23 PM
CSIPSD's Avatar
Get a bowl delete system and ditch the stupid factory leak bowl!
Old Apr 19, 2010 | 02:35 PM
Lawson's Avatar
where do i find such a thing?
Old Apr 19, 2010 | 03:33 PM
CSIPSD's Avatar
ITP 7.3L "Bowl Delete" Regulated Return Kit
Best on the market...
Old Apr 19, 2010 | 04:11 PM
Lawson's Avatar
with that i would have to get an air dog, or the equivalent of right? to use a a water separator?
Old Apr 19, 2010 | 05:16 PM
CSIPSD's Avatar
Two napa filter heads... a 10 micron water/fuel filter and a 2 micron final filter...
Factory only filters down to 12 microns so...
Old Apr 19, 2010 | 07:52 PM
Lawson's Avatar
dam... how much would that cost me... i looked on napas web sight but couldnt find the filters or the heads. do you happen to have the part numbers
Old Apr 19, 2010 | 08:52 PM
NevrKnow's Avatar
Stick a mirror on the back side of the bowl and make sure you have all that yellow ptfe stuff removed or the new o-rings will keep leaking. If that's not it I'm stumped. Will ask around tho.
The cruise control recall is just a new pigtail that plugs into the existing wire on the backside of the master cylinder. Only takes them a couple minutes to fix it. It has nothing to do with the cruise light, could be just the led.
