hurt 91 f350
Old Apr 17, 2010 | 01:31 PM
kevin welch's Avatar
Default hurt 91 f350
I a crew cab f350 truck which i acquired from someone one who only drove it for the past 5 years to go deer hunting. I drove this truck with only 120000 miles on it for two years with very few problems then my son playing in my truck ran my batteries down and me being in a hurry tried to pull start it since i have the 5 speed tranny in it. After dumping the clutch a few times i realized my rear tires where locked up and later after pulling the oil pan i realized i had bent a rod.I am considering just pulling and replacing the rod piston and rings and putting it back together but am scared,also am thinking about getting power stroke out of 94or5 truck i dont have alot of money and dont know what to do what kind of comments do you have for either route i miss my big truck
Old Apr 17, 2010 | 04:20 PM
HAYMAFIA's Avatar
the powerstroke is electronic. u will need gauges and whole wiring harness. oh yeah also fuel pedaL. not too bad a swap but very time consuming.
Old Apr 17, 2010 | 09:32 PM
2MuchJunk's Avatar
If none of the other rods or pistons are bent or broke you could probably just change the one. My big question is why it bent and my guess would be a head gasket or something.
To put a psd in it would probably be a lot of work.
Old Apr 17, 2010 | 09:41 PM
ArizonaRedneck's Avatar
i agree with 2muchjunk if money is an issue replace what you have too and get it running but also why did a rod get bent look into that and welcome to diesel bombers glad to have you around
Old Apr 17, 2010 | 10:17 PM
2MuchJunk's Avatar
Does the truck have a electric fuel pump on it?
Old Apr 18, 2010 | 10:34 AM
HAYMAFIA's Avatar
if you used ether in this truck it may have bent the rod. ether locking one then trying to pull start it will bend things.
Old Apr 18, 2010 | 10:40 AM
12vcummins96's Avatar
i would completely go threw it imo but if and no it has a manual fuel pump on it
Old Apr 18, 2010 | 12:23 PM
2MuchJunk's Avatar
I know factory it had a manual pump on it. The reason I asked is if his kid left the key on and it has a electric one someone put on it could it slowly bled past a wore injector filling the cylinder with diesel causing the rod to bend?
Old Apr 18, 2010 | 02:47 PM
thats a posibility right there especially with a pull start
Old Apr 18, 2010 | 07:15 PM
2MuchJunk's Avatar
The good thing is if thats the case it probably bent the first one up and stopped leaving the others unhurt. You would need to drain the diesel out of them though.
One more thing. I have a friend with a f350 that he is parting out. The 7.3 has some miles on it but runs great with a new fuel system on it. Don't know what he wants for it or how close you are to southern Indiana but if your interested I can ask. Just thought I would through that out there.
Mar 13, 2015 03:40 PM
Mar 10, 2015 07:50 AM
