air bag light 1995 chevy
Old Apr 14, 2010 | 07:13 AM
superburban4x4's Avatar
Default air bag light 1995 chevy
Battery died from sitting all winter. This spring I had to jump it to start it, I also put a charger on it,and ended up putting new battery's in it. And threw all this it caused the air bag light to come on...Any one know how to reset or turn off the air bag light on a 1995 Chevy truck?
Old Apr 14, 2010 | 09:51 AM
tltruckparts's Avatar
i believe you have to have a scanner with air bag abilities if i remember right
Old Apr 14, 2010 | 02:33 PM
I know that that is the easy way with a scanner...but this is a better off modified site? right I know there is a way to do it with a paper clip just dont know the right pins to jump and dont wana go at it with out some for sure tech advice air bag info seems pretty limited in all the searching i have done. I never had a air bag deploy dont really want it to in my drive way thats for sure..
Old Apr 15, 2010 | 12:01 AM
ya i hear ya on that one. ive never done one with a paperclip but i have done the check engine light that way id assume it works the same with the air bag light flashing.
here are a list of the codes i found:
DTC 14 Arming Sensor Disconnected
DTC 21 Driver Initiator Circuit Resistance High
DTC 22 Driver Initiator Circuit Resistance Low
DTC 23 Driver Initiator Circuit Voltage High
DTC 24 Driver Initiator Circuit Voltage Low
DTC 25 Driver Initiator Circuit Short to Ignition
DTC 26 Driver Initiator Circuit Open
DTC 28 Current Sink or Source Failure
DTC 31 Driver Loop Energy Reserve Feed Open
DTC 34 Arming Sensor Ignition Feed Open
DTC 35 Discriminating Sensor Open or Missing
DTC 42 Loop Energy Reserve Voltage Low
DTC 43 Driver Source Feed Low
DTC 51 Frontal Accident Detected
DTC 52 Data Area Full
DTC 55 DERM Incompatibility
DTC 61 SIR Indicator Circuit Failure
DTC 62 Redundant SIR Indicator Circuit Failure
DTC 71 and/or 75 Internal DERM Fault
DTC 83 Driver Reserve Diode Shorted (History)
and here is the info from alldata:
A scan tool is used to read current and history diagnostic trouble codes and to clear all diagnostic trouble codes after a repair is completed. The scan tool may need to be updated to communicate with the SIR system through a replaceable cartridge before it can be used for SIR diagnostics. To use the scan tool, connect it to the data link connector and turn the ignition switch "ON." The scan tool reads serial data from the DERM "Serial Data" output terminal "B11" at the data link connector terminal "9."
A scan tool can also provide SIR system circuit values using the "Data List" function. These values are referred to in the diagnostic trouble code tables to aid in diagnosing certain SIR system malfunctions. For additional information, refer to the scan tool instruction manual.
looks like possibly jumping 11 and 9?
schmauster
Jul 26, 2015 11:33 AM
Jul 24, 2015 09:30 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
airspeed181
Jan 19, 2015 09:00 PM
