Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
low tire pressure light
Old Apr 12, 2010 | 04:04 PM
cummins.1.5.3.6.2.4's Avatar
Default low tire pressure light
ok so my dad had a flat on his 2010 f-350 the other day and of course the low pressure light was on but even after he got the flat fixed and the pressure was back up the light remained on and is still on today so i kinda need help on gettin it to turn off since i know nuthin about fords... also he is gonna throw aftermarket rims and tires on his truck and he dont feel like puttin sensors in the new rims so is there any way to disable this feature completely?? any help would be great guys
Old Apr 12, 2010 | 07:12 PM
1deisel's Avatar
Default .
he still will have to run tps sensors unless he likes the little light on the dash to stay on. as far as the light now make sure all tires are inflated to the tag on the door drive it should go off if the tires were rotated he will have to go to ford and they will reset the sensors with this neat little tool takes bout five minutes.
Old Apr 20, 2010 | 12:14 PM
justsmokeit's Avatar
I have a new ford too. I ran the stock tires for about a week before I made it to the tire shop for the lift and new rubber. They didn't even recommend putting the sensors back on, due to the fact that the air pressure must be 60+ psi for the warning light to shut off, and when running most oversized tires you shouldn't run that kind of pressure (the end result would be pre-mature wear on the center of the tires). The warning light is something I've just learned to deal with.
Old Apr 22, 2010 | 01:47 PM
Superstroker10's Avatar
you can change the psi that the computer reads as the minimum. if you dont want your sensors i'd be intrested in them
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Mr.Gutsy
Feb 22, 2015 11:11 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
