6.2 regular maintenance
Old Apr 10, 2010 | 08:15 PM
86k5's Avatar
Default 6.2 regular maintenance
what needs to be done every so often to keep one of these things alive?
Old Apr 10, 2010 | 10:30 PM
2MuchJunk's Avatar
Change both fuel filters, oil, run clean diesel fuel, and when the engine starts running rough get the injectors pop tested to make sure there not leaking down and are running even. Other than that there is not a whole lot to a 6.2 they are pretty simple.
Old Apr 10, 2010 | 11:02 PM
wildbill's Avatar
Don't run em out of fuel, otherwise the injection pump will go south on ya pretty fast.
Old Apr 11, 2010 | 04:14 PM
Woody35's Avatar
injectors every 100k miles and when you get new ones dont trust the manufacturer. get them pop tested. throw in some 2 stroke oil or 30 weight non detergent oil in every tank to lube up injection ppump because of the lack of sulfur in ulsd diesel
Old Apr 11, 2010 | 06:43 PM
87diesel's Avatar
2 stroke oil??? like how much per tank?
hmm never knew that would be ok
Old Apr 12, 2010 | 04:07 PM
Woody35's Avatar
i got a 26 gallon tank and i usually put in about 16-20 oz
Old Apr 12, 2010 | 07:17 PM
87diesel's Avatar
hm i will have to do that then. thanks for the tip!
Old Apr 12, 2010 | 07:31 PM
Woody35's Avatar
diesel fuel was a lot different when these injection pumps were designed so the way we maintain them has to be different too.
Old Apr 18, 2010 | 11:55 PM
86k5's Avatar
what about the additives? that u can buy off the shelf at auto parts stores? and what kind of places pop test injectors? would any machine shop do it or would it be better left to a diesel specific shop?
Old Apr 19, 2010 | 12:38 AM
2MuchJunk's Avatar
You could put some power service in the tank but I don't really put to much faith in over the counter fix all additives. A injection shop will have to pop test the injectors.
