99 f350 7.3 no oil pressure
Old Apr 8, 2010 | 06:45 PM
majesticremodeling's Avatar
Default 99 f350 7.3 no oil pressure
Truck shut off due to no oil pressure about a week ago. Pulled the oil pressure sensor and tried to start, no oil coming out. Took off harmonic balancer and g rotor cover, g rotor was in great shape but keyway slot on balancer was cracked so I replaced that, put everything back together and still no oil pressure. Have also had oil cooler off and replaced o-rings. Anyone have any suggestions??
Old Apr 8, 2010 | 07:27 PM
CSIPSD's Avatar
Did you check the front cover? I would bet the front cover is scored.
Not sure what the G rotor your talking about is, I would assume your talking about the oil pump?
Old Apr 8, 2010 | 08:13 PM
I removed the front cover, it's not scored.
Old Apr 13, 2010 | 05:53 PM
clem1226's Avatar
pickup tube in the pan? They have been known to crack ( I read it on the net no personal experience). You could try overfilling the crankcase a couple of quarts to see if you could get above the crack as a diagnosis.
Old Apr 13, 2010 | 08:43 PM
I got it, a fuse was blown that goes to the fuel bowl, running like a champ now.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
