95 Powerstroke just chugs
Old Apr 7, 2010 | 11:46 PM
lcritter78's Avatar
Default 95 Powerstroke just chugs
I have a 1995 Powerstroke with the complete Banks upgrade( chip, turbo, inter-cooler, exhaust, transmission cpu) it has 157K miles on it and i just bought it 6 mouths ago and love this truck would not trade it for anything but this is my first diesel and don't know much about them but in ran great purred like a kitten. 2 weeks ago the truck just shut off when i was driving it to work was able to start it a few minutes later. but after that point when it is at idle it just chugs and it seems like it lost most of its power. it will start OK and it dose freeway speed i have replaced the cam positioning sensor. I changed the oil, i changed the fuel filter. now i am not sure because i did not look at it a lot i was sure that the exhaust temp used to stay around 300 when i was not pulling my 5th wheel but now they seem to sit around 350
Old Apr 8, 2010 | 08:10 AM
DieselDanBoy's Avatar
smoke?? if so what color? im assuming fuel mileage is down considerably?
Old Apr 8, 2010 | 10:31 PM
lcritter78's Avatar
some white smoke but not much and it seems to go away after running for a little bit. fuel mileage is down as well
Old Apr 9, 2010 | 07:14 AM
a little smoke when it starts?
Old Apr 9, 2010 | 10:13 AM
lcritter78's Avatar
yes when it starts but it goes away
Old Apr 9, 2010 | 02:22 PM
Budgreen's Avatar
boost pressure? any loss in that
Old Apr 9, 2010 | 10:14 PM
lcritter78's Avatar
the turbo seems less but not much less
Old Apr 11, 2010 | 05:38 PM
lcritter78's Avatar
when it is chugging it is blowing dark smoke out the tail pipe
Old Apr 25, 2010 | 07:46 PM
lcritter78's Avatar
if i had a bad glow plug would that cylinder ever start on its own
Old Apr 26, 2010 | 04:54 PM
no it wouldnt, your other cylinders would fire and eventually bring them all up to speed, it would lope when you started it as well if you had more than one bad glow plug. that would also produce some white smoke when you started it.
dark as in black smoke?
