Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Lubricity And Diesel Fuel Grades
Old Sep 10, 2007 | 02:39 PM
Whit's Avatar
Site Mascot
Default Lubricity And Diesel Fuel Grades
What is the difference between No. 1-D diesel fuel and No. 2-D diesel fuel and can they be used interchangeably?
Always check with the manufacturer about the fuel requirements of your engine. However, both No. 1-D and No. 2-D are intended for use in compression ignition engines. In fact, in cold weather, No. 1-D is blended into No. 2-D or used by itself.
Three of the biggest differences between the two fuels are cetane number, heat content, and viscosity. The cetane number of No. 1-D may be one to two numbers below that of No. 2-D, but still above 40, the required minimum.
Since No. 1-D is less dense then No. 2-D, its heat content, measured in Btu/gallon, will be a few percent lower, leading to a similar reduction in fuel economy.
The lubricity of No. 1-D is likely to be slightly lower than that of No. 2-D because of its lower viscosity. Its lubricity is unlikely to be low enough to cause catastrophic failure. However, a steady diet of No. 1-D in equipment designed for No. 2-D may result in greater long term wear in the fuel delivery system.
Old Sep 22, 2007 | 09:12 PM
handymanherb's Avatar
Banned
Doesn't mater to me , I can't get anything but ULSD around town
Old Sep 23, 2007 | 03:40 PM
Whit's Avatar
Site Mascot
ULSD comes in #1 and #2 grades
Old Jul 4, 2013 | 05:01 PM
DieselGeek's Avatar
same here ULSD I used the Diesel keen and Diesel centane booster every other tank so for 167K and no issues
Old Jul 5, 2013 | 01:29 AM
2004LB7's Avatar
for anyone interested in more info about lubricity, here is an interesting test published on another site: Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
PS: Diesel Kleen did not score too high on the test but was better then straight diesel
and the chart
Old Dec 4, 2013 | 10:14 PM
DalilaFetter's Avatar
now the time i am looking for the specs to decide over the differences .. though have not got the comparison in such a detail before
wolfnexus
Nov 4, 2014 10:04 PM
