Please Help me out here
Old Apr 6, 2010 | 09:29 AM
fumminsplease's Avatar
Default Please Help me out here
Does any one know if a 5.9 cummins out of a school bus will bolt to a 47rh transmission? Most of them are decently priced and they were hooked to at 545's. Thanks
Old Apr 6, 2010 | 11:26 AM
the_new_kid's Avatar
just about any transmission will bolt up it just depends what adapter plate you have on the back of the cummins motor.
Old Apr 6, 2010 | 12:33 PM
How do you know what adaptor plate is behind your engine? Ive heard of Sae 1, 2, and 3 do the dodge trannys bolt to any of these?
Old Apr 6, 2010 | 08:38 PM
The dodge adapter is not the sae 1,2 or 3 there is an actual dodge adapter along with a ford one and if you go to www.destroked.com they have adapters for a cummins to just about any ford engine. Pricey but they look like quality adapters
Old Apr 6, 2010 | 10:34 PM
O ok, If I was to buy a cummins that was on a bus with a allison tranny hooked to it what would it take to hook the dodge tranny to it? I'm also concerned that some of the cummins didnt have the motor mounts where the dodge version had them. I think they are by where the tranny bolts up. Don't know if you could answer that but anything is greatly appriciated.
Old Apr 7, 2010 | 06:10 AM
the adapter i believe will NOT be the same as the dodge one but those dodge ones are not to hard to find.
As for the motor mounts there are so many ways and options to hook them up.
Some will connect to the side of the block in the middle some in the front some in the very from some are straight some are angled. Many people make there own so that road is optionless as far as a conversion goes.
If you can weld and fabricate just make your own to fit where you want them.
I don't know if you can also go to www.4btswaps.com even if you are using a 6bt everything is the same just the length of the motor.
