How to calculate travel?
Old Apr 6, 2010 | 04:55 AM
08F250SD's Avatar
Default How to calculate travel?
I am looking at Fox Racing Shox and since they are sold by amount of travel I was wondering how you calculate how much wheel travel a vehicle has.
Old Apr 6, 2010 | 07:06 AM
Whit's Avatar
Site Mascot
I believe it would be the distance frm when the wheel has no weight on it at all to fully compressed
Old Apr 7, 2010 | 06:26 PM
Karls03's Avatar
1. support you rig by the frame
2. remove shocks, may need to remove a tire from side you are going to measure on
3. put a jack under the OPPOSITE tire and crank it up until it is about to lift truck off of jack stand
4. with opposite side drooped, measure from say the top of a trailing arm close to the axle to a spot on the frame, this will be your extended length. Best to add an inch don't want to hyper-extend your shock. If you measured 12 inches, go for 13.
5. remove jack and put under side you just measured and jack up, measure to same spot, this will be your compressed length. Best to SUBTRACT an inch, don't want to smash your shock. If you measured 6 inches, go with 5.
6. subtract the second number from the first and this will be your travel, although it's been my experience that compressed and extended are what you are after.
Last edited by Karls03; Apr 7, 2010 at 06:29 PM. Reason: failure to read and follow instructions...
Old Apr 7, 2010 | 07:41 PM
RSWORDS's Avatar
That sounds right. I would call fox. I'm sure they have some directions they can fax or email you.
dallasca
28
May 26, 2015 12:58 AM
dba
Nov 26, 2014 10:28 AM
