Military H2 rims and 37" tires?
Old Apr 5, 2010 | 10:22 PM
LB7DuramaxMeggers's Avatar
Default Military H2 rims and 37" tires?
I got a buddy that is in the military and he can get the humvee rims and tires real cheap, so i was wondering if anyones got any pictures of what this would look like before i buy em?
-also are 37" tires gonna fit on a stock height 4wd duramax?
Old Apr 5, 2010 | 10:31 PM
2500HeavyDuty's Avatar
37's won fit, they wont even be able to fit inside the fender well at stock height. i have 35's and im close to everything.
and ae they the h1 or h2 wheels?
Old Apr 6, 2010 | 05:33 PM
dmaxtothemax's Avatar
Hmmm... i'd be interested in seeing these wheels too... please post if someone gets pics of them... Sorry, i have no resource or I'd post
Old Apr 6, 2010 | 08:50 PM
CSIPSD's Avatar
If there millitary they will be H1's... And they will also be bias ply... not fun on the road.
I ran some for about 20 miles, turned around and gave them to the tire shop, just to get my old ones remounted...
Old Apr 6, 2010 | 10:46 PM
and they arent rated for that high of a speed either.
Old Apr 6, 2010 | 10:51 PM
FastCR's Avatar
newer humvee tires are radial. mounted on 12 bolt rims. The bias ply are the old ones and were on 8 bolt rims. I have radials on my truck.
H1 wheels and tires are 16.5" not 17s, and the backspacing is awful. Basically its probably not gonna work.
Old Apr 7, 2010 | 10:20 AM
K50's Avatar
K50
I thought H1 wheels had planetary hubs anyways...does that affect the rim design too?
Old Apr 7, 2010 | 03:58 PM
DIRTYMAX2004's Avatar
35's on a stock hieght Duramax??? you must have a leveling kit or something. i am running 35's with a 4" suspension lift and i had to cut the corners off the bottom plastic piece to keep them from rubbing while driving (they still rub if i hit a big bump). 33's where the biggest tire i could fit on mine while it was stock hieght and they rubbed on bumps.
You will need at least an 8" lift to run 37's on a chevy. They might fit with a 6" lift but it would be damn close.
Oh i suppose if i can remember i will take a picture of the rims and tires on a H1 humvee tomorrow. i have very bad memory so most likely i will forget.
Last edited by DIRTYMAX2004; Apr 7, 2010 at 03:58 PM. Reason: Automerged Doublepost
Old Apr 7, 2010 | 10:03 PM
The tires i have n my truck in my sig pic are 315/70/r17
and my cv angles are flat, it does bottom out of i jump a speed bump hard enough
Old Apr 9, 2010 | 03:09 AM
Karls03's Avatar
H1 wheels are great if you have done an axle swap that is a little wide and you want to tuck the tires back under the rig. They are all but flat on the exposed side like a front wheel drive rim. These rims are were made for a purpose, NOT for looks. ie, they're pretty ugly.
