Need help w a code???
Old Apr 5, 2010 | 08:18 PM
6.7 MoJo's Avatar
Default Need help w a code???
So i got the phantom overhead thing again..but this time Smarty found a code: P0513 Invalid skim key.
There was no cel..just the OHD saying see dealer now. Truck seems fine..cleared it and carried on...but can someone shed some light on what that code means....
Thnx
Mike
Old Apr 5, 2010 | 10:17 PM
my09cummins's Avatar
Not 100 percent but pretty sure that you get that from shutting the engine off without pullin the key out or opening the door, you'll be fine
Old Apr 6, 2010 | 10:15 PM
6.7 MoJo's Avatar
Anybody else know for sure....
Old Apr 7, 2010 | 02:09 AM
MarineOne's Avatar
The invalid skim key is mostly due to using a replacement key without the FOB on it, basically meaning it knows the key is good but can't sense the chip in the key.
Is it a new key or one you haven't used in the truck for a while?
Kris
Old Apr 7, 2010 | 08:41 AM
6.7 MoJo's Avatar
It's the same factory key I have been using...I guess Maybe it was a glitch? I just wanted to make sure it was What it Sounds like.
Old Apr 7, 2010 | 10:41 AM
MarineOne's Avatar
Prolly just didn't "see" the chip in the key .... I wouldn't worry about it.
-K
Old Apr 7, 2010 | 12:50 PM
P0513-invalid Skim Key - Dodge Cummins Diesel Forum
this will tell you about it
Old Apr 9, 2010 | 05:29 PM
ETXBlueRam's Avatar
Thnx
Mike
P0513 is nothing to worry about. Most of the time, it comes up when you are cycling the key to pull codes...and try again too soon... or if you shut the truck off and restart it too quickly. It is a conditional reset code in that if, after X number of key cycles it doesn't detect anything wrong, it will clear itself.
As for the overhead saying see dealer, scan for codes with the Smarty, and even though it will say that there are no codes present, tell it to clear them anyway. That will make the see dealer message go away.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
