Injection Pump Issues
Old Apr 5, 2010 | 04:04 PM
Fullpull's Avatar
Default Injection Pump Issues
My Injection Pump went out going down the road dangit. I'm getting it from the tank to the filter and in the filter bowl. Just not from their to the injectors. Can somebody tell me if its the Injection Pump or something before I go blow $604 dollars.
Old Apr 5, 2010 | 04:32 PM
DieselCrawler's Avatar
hotwire the pump. send power to the prong on the pump closest to the radiator. that will turn on the pump then try to start.
Old Apr 5, 2010 | 07:40 PM
Sycostang67's Avatar
Yeah, make sure if wasn't just the fuel shutoff solenoid that failed. Run a hot wire to it and you should hear it click when you touch the prong with the wire.
Old Apr 5, 2010 | 08:26 PM
Fullpull's Avatar
You guys are the greatest!!!! I will try that first thing.
Old Apr 11, 2010 | 10:04 PM
Fullpull's Avatar
well i put a new injection pump on it. didnt work, so i put a new fuel filter on it. didnt work, so im putting a new mechanical fuel pump on it hope it works. I had a guy at the auto parts store tell me that they also have a pump in the fuel tanks. IS THIS TRUE?????
Old Apr 11, 2010 | 10:35 PM
The gas trucks(fords) have in tank pumps, the as far as I know, the diesels do not.
Old Apr 12, 2010 | 06:07 AM
no pump in tank.
Old Apr 12, 2010 | 05:12 PM
Fullpull's Avatar
ok good, i just put the mechanical pump on it. It still wont start. its getting fuel from the pump to the fuel filter i know for sure. what could be wrong with it???? I know air in the lines, but it started up and ran for about 5 minutes and died
Old Apr 12, 2010 | 06:15 PM
gona ask this like i always do, how much fuel is in the tank? dual or single tanks?
Old Apr 12, 2010 | 08:01 PM
Fullpull's Avatar
duel tanks and it has 1/4 tank in it. The guy at the auto parts store also said they had to be timed. which i didnt believe.
