Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Will Low Sulfur Diesel Or Low Aromatics Diesel Cause Fuel System Leaks?
Old Sep 10, 2007 | 01:47 PM
Whit's Avatar
Site Mascot
Default Will Low Sulfur Diesel Or Low Aromatics Diesel Cause Fuel System Leaks?
Will low sulfur diesel or low aromatics diesel cause fuel system leaks?
The introduction of low sulfur diesel for on-road use in the U.S. was accompanied by fuel system leaks in a very small percentage of vehicles. Investigations into the cause of these leaks suggest that the problem was linked to the change in the aromatics content of the fuel and to seal material and age.
Diesel fuel systems contain "O-rings" and other parts made of elastomeric materials. These elastomers swell slightly when they contact diesel fuel, because they absorb aromatic compounds from the fuel. Exposure to a fuel with a lower aromatics content will result in some of the absorbed aromatics being leached out, causing the elastomer to shrink towards its original size. If the elastomer is still pliable, this shrinkage will not cause a leak. However, if age or service at higher-than-normal temperatures has caused the elastomer to loose its elasticity, a leak could occur. Vehicle owners should be aware that elastomeric parts have finite lives and should be replaced as necessary.
By itself, low sulfur or low aromatics diesel fuel does not cause fuel system leaks. They are caused by the combination of a change from higher to lower aromatics fuel and aged O-rings and elastomeric parts that have lost their elasticity.
My experience with O-rings where they can absorb aromatic compounds is when you replace them go with EPDM, CALREZ or VITON........we deal with this at work every day
Cheers,Kevin
Old Sep 10, 2007 | 01:59 PM
Any idea how $$ Calrez is??
Old Sep 10, 2007 | 02:15 PM
Whit's Avatar
Site Mascot
more expensive than byutel (SP) by prolly 10x but the cost of the o-ring is minor compared to the labor costs to replace said o-ring
Old Mar 7, 2011 | 05:03 AM
Truckboy's Avatar
Yes definitely, low aromatics in the diesel fuel may cause IP pumps seals and other fuel system o-rings to fail and will cause the seals to shrink. Low sulphur fuel will cause a big problem with diesel fuel system injection pumps burning out.
___________________________________
Scooters For Sale | Motorcycles For Sale
Old Nov 11, 2012 | 07:50 AM
kyled's Avatar
How often should the o-rings be replaced in a car and how expensive should it be? Any recommendations about where to get it done in Ohio.
Old Oct 28, 2014 | 01:40 PM
fijitec's Avatar
i would assume if seals are worn and old they will cause system leaks as seals would fail
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
wolfnexus
Nov 4, 2014 10:04 PM
