06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
PPE Hot+2
Old Apr 3, 2010 | 01:02 AM
dieselpowermark's Avatar
Default PPE Hot+2
who out here can tell me how it is as a programmer setup?
dont respond by saying you should run EFI live had too many problems with it and dont want it!!!!!
Old Apr 3, 2010 | 07:19 AM
Tyler@MPF's Avatar
The Hot+2 is a great tuner. You do need alot of supporting mods if you plan on trying to take full advantage of the unit. You can run up to the 160 hp tune and be relativiely safe. You would still have to be careful with how you drive of it could result in transmission failure.
Old Apr 3, 2010 | 04:11 PM
The PPE is the best out of the Box Programmer for the Dmax. Like Tyler said above the higher settings require supporting mods. The biggest problem with running the High Settings is the Stock Transmission and stock Fuel System.
Old Apr 4, 2010 | 09:19 PM
BriteWhiteRam's Avatar
Agreed, the PPE is the ultimate plug and play for the Dmax, but the trans wont take the higher settings and your gona need a Lift Pump and maybe another CP3 to be able to get all the fuel that it can program
Old Apr 4, 2010 | 09:23 PM
emiller3's Avatar
And a bigger charger to clear things up.
Old May 3, 2010 | 02:53 PM
STACKED07's Avatar
I have this tuner and this is what I have seen, after level 5 there is no point without a bigger turbo and or dual cp3 pumps. It is strong, at a min. You need a lift pump, shimmed fuel rail, ported fuel rail fittings, some tranny work, o yeah and some new u joints, well maybe that was just myt truck. The ppe hot demands fuel, its good and I like mine, but I want to upgrade to efi live.
Old May 19, 2010 | 11:34 PM
66impala's Avatar
i run a PPE hot +2 in setting 4 with my lly with the lbz tune thanks to the dealer. love it would recomend anything else
Old May 20, 2010 | 01:56 AM
EvilBowtie's Avatar
i run the ppe hot+2 and i have efi live .... the hot+2 is the best handheld plug and play tuner available !
Old Jul 1, 2010 | 03:08 PM
w-dmax's Avatar
also the defuel is a good thing
Old Jul 1, 2010 | 04:13 PM
kmkdiesel's Avatar
the biggest thing I have seen with it, is with out alot of supporting mods on the higher settings, after you do a good wot run, it will throw a cel and put the truck into limp mode, I have put quite a few of them on trucks and really like them.
j1004ss
9
Dec 23, 2021 02:59 PM
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
01LB7Duramax
Wanted To Buy (WTB) - Used
Mar 3, 2015 08:04 PM
