what tha $&%!
Old Apr 2, 2010 | 07:18 PM
cummins joe's Avatar
Default what tha $&%!
2007 dodge 2500 5.9 i turn on the right blinker and in the instrument panel blinks right, turn on the left turn signal, AND IT STILL BLINKS RIGHT !!!!!!! also, no left turn signal outside the truck, front or back. PLeASe HELP
Old Apr 3, 2010 | 02:38 AM
ArizonaRedneck's Avatar
do you have a trailer plug look there and see if your not getting some wire touching
Old Apr 3, 2010 | 08:39 PM
mjp5318's Avatar
might have a bad ground as well .. Had that happen in my 95 ram .
Old Apr 3, 2010 | 08:54 PM
psmike's Avatar
ok. had that happen to me in a ford ranger.. turned out the bulb burned out an the filament droped an i think it was from the blinker to the running light so when the blinker was turned on it would backfeed to the dash lights.. so might wanna check your bulbs..
Old Apr 3, 2010 | 09:03 PM
mjp5318's Avatar
Default light
[QUOTE=psmike;530077]ok. had that happen to me in a ford ranger.. turned out the blub burned out an the filament droped an i think it was from the blinker to the running light so when the blinker was truned on it woud back feed to the dash lights.. so might wanna check your blubs..[/QUOTE
On my ram the left rear shorted out because the ground was loose and my whole car would flash when I turned on the turn signals ..
Old Apr 3, 2010 | 09:08 PM
Benjamin's Avatar
Bombardier
if all the lamps check out good, (it won't take but a few minutes to pull them out of the housings and check them out) the next thing i would look into replacing would be the turnsignal switch on the steering column.
Old Apr 3, 2010 | 09:14 PM
bobcat67's Avatar
whooot whooot dodge wiring at its finest again
Old Apr 5, 2010 | 10:25 PM
crazycarl's Avatar
Check for pinched wires about 8 inches from the turn signal switch down the steering column. a freind and I chased that same problem for a mounth on his 2500, the only diffrence is his was not a constant failure. just an idea
Old Apr 5, 2010 | 11:05 PM
robammerman's Avatar
I bet you've got something jacked up in your multi-function switch. (turn signal switch)
If anything, you could leave it and surprise a lot of people.
Old Apr 6, 2010 | 07:42 AM
mkostersitz's Avatar
Have seen this in my '04 3500. Issue was a short in the trailer plug where the right turn wire was corroded to ground about 10 inches into the tree.
