Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
jeep questions
Old Mar 31, 2010 | 09:48 AM
moneyman_09's Avatar
Bomb jeep questions
I found a 92 cherokee that blew a rod it has the 4.0 in it for 300 i am thinking about getting it because i found a 99 4.0 for 100 bucks but i was wondering if the 99 motor will match up to the 92 drive train Thanks for the help hopefully this turns into a fun mud and trail toy
Old Mar 31, 2010 | 10:46 AM
sneed1rr's Avatar
FormerVendor
It should work fine, they never really changed anything about the xj's other than minor exterior and interior changes
Old Mar 31, 2010 | 07:31 PM
Thats one idea i just had a friend offer me his 93 grand cherokee but it has a bad trans for 500 it has a 3 inch lift but is full time 4 wheel drive what is better for off road fun. There both beat up so i'm not worried about that i'm talking like which one has better capabilities off road
bump
Last edited by moneyman_09; Mar 31, 2010 at 07:31 PM. Reason: Automerged Doublepost
Old Mar 31, 2010 | 08:30 PM
sneed1rr's Avatar
FormerVendor
They both do great offroad, I like part time alittle better just so I can put it in 2wd and slide around alittle easier in the mud and snow.
Old Mar 31, 2010 | 09:28 PM
yea i'll see
Old Mar 31, 2010 | 10:46 PM
24v'd_Fury's Avatar
92 is the non "high output" motor and the 99 is "high output"
Motor wise there pretty much the same exept the crank sensors and some other random stuff but it'll work as long as you dont get a motor from the late 80's XJ's.
Old Mar 31, 2010 | 11:03 PM
thanks has anyone heard of a one year only trans for a 93 grand cherokee the guy at the shop said that it had like a 42re and it was junk. so i found a trans from a 97 4.0 for 100 bucks will it work?
Old Apr 1, 2010 | 03:43 AM
sneed1rr's Avatar
FormerVendor
They started the high output in 91 the only difference is in 99 they changed the intake manifold
the AW4 tranny was used in the grand cherokee in early 93 and changed to a 42re mid year so the AW4 is probably what he is talking about, jeep ran that tranny for a long time in the cherokees and comanches but only for half a year in the grand cherokees
Old Apr 1, 2010 | 10:17 AM
yea he said he took the intake manifold off of this engine
Old Apr 1, 2010 | 10:34 AM
glfredrick's Avatar
Physically, everything will bolt up and work just fine. Computer and engine management related, you may need to swap out some of the newer components for the original ones that work with the vehicle PCM unless you are willing to convert to the later model wiring and computer.
The XJ is a fun and capable off-road machine. Both of my kiddos built XJs that did very well.
One thing to watch for is the unit body. It can develop cracks from twisting after a while. Lots of ways guys handle that, from plating the frame rails to building cages, but they are okay until you start going big on tires and axles.
