OD, Speedometer, and some other stuff
Old Mar 29, 2010 | 10:16 PM
dan.g's Avatar
Default OD, Speedometer, and some other stuff
This whole thing is really driving me off wall.
It all started with a broken speedometer-so i replaced the VSS checked the gears and made sure it had 8v to it- no luck- replaced the ABS sensor-no luck-then my whole cluster stopped working! There is no obvious loose ground.
I need to drive across country at the end of the week and i'm beginning to get worried. I tried briefly to wire a switch for he OD so i could at least get to highway speed, but didn't have any luck.
Can anyone give a hint as to what to try next? Or if you have any idea about how to get the OD solenoid on a manual switch?
thanks,
dan g.
Old Mar 30, 2010 | 05:17 PM
Jet A Fuel's Avatar
Sounds like a PCM or voltage issue to the PCM but I don't know if the 92 trucks had one back that far.
Welcome to Diesel Bombers!
Last edited by Jet A Fuel; Mar 30, 2010 at 05:17 PM. Reason: Automerged Doublepost
Old Mar 30, 2010 | 11:39 PM
gradyc's Avatar
Our 92 has a pcm. It controls the O.D shift, cruise control and is the regulator for the alternator. It sounds like a broken wire in the harness somewhere. If it will help I have the factory manual on C.D. that I can send wiring diagrams to you. Ours started acting up before I got the manual and I added an outside voltage regulator and hydraulic switch for the O,D shift.
Old Mar 31, 2010 | 12:21 AM
moneyman_09's Avatar
I'm having kind of the same problem my od does not work neither does my cruise control the truck dies if i take my foot off the petal my speedo works tho idnn if it's cause it is 4 wheel drive tho. How much is a pcm and where is it located
Old Mar 31, 2010 | 01:47 AM
gradyc's Avatar
I don't know how much they cost but it is located inside the left front fender behind the battery.
Old Mar 31, 2010 | 09:11 AM
Thanks
