02 duramax help
Old Mar 29, 2010 | 09:11 PM
ltr450's Avatar
Default 02 duramax help
this is not my truck. it is a 02 130000 miles on it and it kepts getting lots of fuel it the oil. it had new injectors with the last 15000 miles what else could it be or is the injectors shot again
Old Mar 29, 2010 | 10:50 PM
2500HeavyDuty's Avatar
definitely sounds like injectors, theres an array of tests that can be done to determine what is wrong, but the valve covers gotta come off anyhow
Old Apr 12, 2010 | 06:15 PM
02 2500hd's Avatar
what did you come up with?
Old Apr 25, 2010 | 04:53 PM
DuraTitus's Avatar
It could be the CP3 but It sounds like injectors.
I would take the valve covers off then reassemble the wiring enough to start the engine, then you can look for leaks while it is running.
Did you replace the return line banjo seals when you did the injectors?
Also did the injectors come from Pensacola Diesel?
Who installed the injectors?
I am sending you a PM!
Old Apr 26, 2010 | 11:43 AM
C-Power's Avatar
agreed, its for sure your injectors, or your return line is leakin bad,
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
Dec 3, 2014 08:10 AM
