cel with sims and dpf
Old Mar 28, 2010 | 10:07 PM
hntruckman's Avatar
Default cel with sims and dpf
well i put my stage two flo pro in the truck saturday morning along with the sims from rollin smoke. i waited for my juice to clear codes on start up and fired it up. let it run and bout 30 secs later cel comes on i check the codes and it says p200c and p200e wat could be causing this?
Old Mar 28, 2010 | 10:42 PM
Rollin Smoke Diesel's Avatar
FormerVendor
Those are catilyst over temp and exhaust bank 1 over temp. This is not all that uncommon with the Edge when using sims and deleting the DPF.
James
RSD
Old Mar 29, 2010 | 07:54 AM
hntruckman's Avatar
have you ever heard of the sims causeing engine damage one of my buddies said he knows someone that sims caused engine damage to.
Old Mar 29, 2010 | 08:08 AM
FormerVendor
No sir, in the past three years, we've sold hundreds of them and have never heard of them causing any engine damage.
James
RSD
Old Mar 29, 2010 | 09:58 AM
hntruckman's Avatar
Ok so is there anything i can do to get rid of the cel.
I JUST READ ON H&S THAT THE SIMS CAUSE A CEL THAT CAN NOT BE CLEARED BY CODE CLEARING DEVICE TILL REMOVED FROM VEIHICLE. CAN I RUN THE TRUCK WITH OUT THE SIMS?
Last edited by hntruckman; Mar 29, 2010 at 09:58 AM. Reason: Automerged Doublepost
Old Mar 29, 2010 | 01:33 PM
FormerVendor
Without the sims the truck will go into regen.
James
RSD
Old Mar 29, 2010 | 01:44 PM
hntruckman's Avatar
OK so ill need to got to a smarty or xrt eventually to get rid of the cel and be code free. for egr delete and dpf delete.
Old Mar 29, 2010 | 05:27 PM
FormerVendor
Thats the strange thing with the Edge and codes. We have had customers using your setup that have had zero codes and others who have them show up. I believe it has something to do with the one zillion flashes they have put on the trucks.
To answer your question, the only way to be code and CEL free would be the H&S or Smarty tuners.
James
RSD
