dieing at random
Old Mar 27, 2010 | 10:18 AM
c0zgrove's Avatar
Default dieing at random
hey guys i have a buddy with a 96 k2500 6.5l auto with 189000 miles the wierd thing is it randomly dies and then sometimes it runs great for a week and then it might die 10-11 times in 6 miles any ideas what could be causeing this problem ive seen all the threads about the pmd just wondering if i should check something else
thanks for any help guys
Old Mar 27, 2010 | 12:03 PM
Woody35's Avatar
did you replace the fuel filter and make sure the fuel system is clean. there is a sock in the tank that can get clogged sometimes
Old Mar 27, 2010 | 12:15 PM
c0zgrove's Avatar
well my buddy told me that he ran it out of diesel and then thats when he started having the problems with it do you think it could be the sock
Old Mar 28, 2010 | 02:06 PM
c0zgrove's Avatar
bump
Old Mar 28, 2010 | 03:56 PM
Woody35's Avatar
he probably still has air in the fuel system. have him turn the key on so the lift pump runs and unscrew the bleeder screw on the fuel filter till diesel comes out. then screw it abck down and start the motor. then inscrew the t-handle at the front of the engine till you see the diesel come out and wait for the air bubbles to get out. then the sytem should be air free.
Old Mar 29, 2010 | 01:45 PM
c0zgrove's Avatar
ok thanks ill try that too
Old Mar 30, 2010 | 08:29 PM
Woody35's Avatar
did it work
Old Mar 30, 2010 | 11:31 PM
dieselpowermark's Avatar
another thing you can try is to turn the valve on the front of the motor and drain the fuel in a jar. let it sit over night inside and look at it in the morning. if you can see clear down at the bottom you got water. add some alchohol and itll clear it up a little and it will run on it. done it many times.
Old Mar 31, 2010 | 04:17 PM
c0zgrove's Avatar
i think its the pmd everything else seems ok
Old Mar 31, 2010 | 11:50 PM
do you have access to anothr 6.5?
