THE WILSON THRASHER INTAKE MANIFOLD HORN
Old Mar 27, 2010 | 03:21 AM
MUSCLE1's Avatar
Default THE WILSON THRASHER INTAKE MANIFOLD HORN
LOOKS REAL GOOD IT COMES WITH THE RAM PLATE WITH A BIGGER HOLE IN IT AND THE HORN HAS ABIG OPENING TO MACH THEY MADE IT FOR THE CO. TRUCK FIRST THEY PULL16000 LBS AND SAID THEY GET 18 MPG TOWING ? HAS AHY ONE USED ONE??? IT ABOUT 500$ FOR THE 2 PARTS AND ALL YOU NEEDTO DO THE JOB
Old Mar 27, 2010 | 08:13 AM
Jet A Fuel's Avatar
When you type in capitol letters its like yelling at people in the forums. It's good forum etiquette not to type in all caps . On the subject of an intake how bout this package deal from S&B ..........
Package - $100 Rebate
Old Mar 27, 2010 | 09:30 AM
dangerous1965's Avatar
How about a pic!!
Old Mar 27, 2010 | 05:30 PM
DB Admin's Avatar
Banned
never heard of it
Old Mar 27, 2010 | 07:30 PM
You would think that if you machined a complete system the Horn would cover 80% of the intake! But hey I don't have a cnc machine to play with! It looks great! Wish i had 5 bills to throw at it!
Old Mar 27, 2010 | 08:46 PM
NadirPoint's Avatar
Injector lines and sensor ports won't allow it. I believe the later generation intake manifolds represent a pitiful compromise for that reason. The horn enters the manifold right at #2, so it's hard for me to see how they get a balanced intake charge across all cylinders. Probably also the main reason #5 & #6 pistons are always the first to melt.
That Wilson Thrasher is an excellent-looking idea/piece, as long as you don't need the grid heaters.
Old Mar 28, 2010 | 02:18 AM
MUSCLE1's Avatar
if i recall right they said it was tested to start eng. down to 9 degrees with out a heater i call and talk with them on 3-29-10 "and they are working with cummins right now on a heater set up " so they say
Last edited by MUSCLE1; Mar 29, 2010 at 11:04 AM. Reason: i was wrong on the degrees not - 9 just 9 degrees
Old Apr 4, 2010 | 02:06 PM
wes-cummins's Avatar
what if you stuck a couple glow plugs in the intake plate and wired them up, it wouldnt be as good as a grid but i think it would help.
caissiel
Sep 24, 2015 05:37 PM
Finn92
Jan 6, 2015 05:54 AM
ramrunner01
18
Oct 30, 2014 12:35 PM
