5.9/6.7 swap
Old Mar 16, 2010 | 08:50 PM
brk126's Avatar
Default 5.9/6.7 swap
ok heres the deal wanna swap out my 6.7 for a 5.9......if i get one with a computer out of a 2007 will it hook right up or what will i need to change
Old Mar 16, 2010 | 09:30 PM
ForcedInduction's Avatar
The big issue is its illegal.
Old Mar 16, 2010 | 09:57 PM
Diesel Dummy's Avatar
No its not!!! emissions goes by the year of the engine not the truck. It is not a unplug/plug in swap, alot of differences between the 5.9 and 6.7 especially the wiring.
Old Mar 16, 2010 | 10:01 PM
Originally Posted by Diesel Dummy
Emissions goes by the year of the engine not the truck.
That is half false.
Any engine installed into a vehicle must meet the emissions standards of the same year or newer similarly configured production vehicle (The exception being antique vehicles over 25 years of age). Since there is/was no 5.9 Dodge available after the 6.7's introduction, swapping a 6.7 for a 5.9 is illegal until 2032.
FYI, adding lots of exclamation points doesn't change factual data.
Old Mar 16, 2010 | 10:05 PM
FastCR's Avatar
Ignoring the emissions/legality issue, you could put the 5.9 head on the 6.7 block and bottom end. that'd be a prime *** setup.
Old Mar 16, 2010 | 10:08 PM
Whats wrong with the 6.7 head?
Old Mar 17, 2010 | 11:45 AM
dodgeram082500's Avatar
in 2007 you could get a 5.9 or a 6.7 so he should be good to go on the other hand i bet the wiring would be a night mare I would find a donor truck for parts
Old Mar 17, 2010 | 04:01 PM
hntruckman's Avatar
WATS WRONG WITH YOUR 6.7L
Old Mar 19, 2010 | 08:40 PM
brk126's Avatar
I can't keep a headgasket in the thing
Old Mar 20, 2010 | 06:33 AM
Originally Posted by BLACK RHINO
This message is hidden because BLACK RHINO is on your ignore list.
That depends on the manufacture date. There was a mid-year cutoff on when you could get a 5.9, just because you've got a 2007 6.7 doesn't mean you could have bought a 5.9 from the factory instead.
What have you done in attempt to keep it good?
