Timing cover?/ Timing?
Old Mar 16, 2010 | 01:30 PM
Overmodified's Avatar
Default Timing cover?/ Timing?
Hi all I am new to this forum. I drive a 1997 Dodge 3500 with a 12v 5.9 Cummins. It has had a small leak around the front seal for a couple of years. Lately it has been getting worse so I started to pull it apart to fix it today. I have remooved the rad,harmonic balencer,fan bracket,and the timing cover. When I remooved the cover a dowell fell out on the floor and I cant tell where it came from. It also looks beat up like it has been floating around in there for a while. Also this truck seems to be gutless and I am wondering if now may be the time to reset or check the timing.
Ok so I found on here what it is and where it came from but can I leave it out and forget about it ? I am still looking for the timing proceedure.
Last edited by Overmodified; Mar 16, 2010 at 01:30 PM. Reason: Automerged Doublepost
Old Mar 16, 2010 | 01:34 PM
FastCR's Avatar
P7100 Injection Pump Timing Proceedure. - DieselRam.com
you can just time it with the timing pin, but the better way to do it is to find true TDC by doing the valve drop thing.
You got REALLY lucky that that dowel didn't find its way between 2 gears.
Old Mar 16, 2010 | 06:22 PM
The seal kit I bought comes with a plastic sleeve and a metal ring and it is nothing like the one I took out has any one seen this before? I am assuming the ring gets pushed into the opening on the cover after the seal? Then whats with the plastic sleeve?
Old Mar 16, 2010 | 08:22 PM
Rexy's Avatar
let me know what you find out im doing the exact same thing you are. look at my pics on my post in 12 valve section.
Old Mar 17, 2010 | 02:49 AM
gradyc's Avatar
The metal ring and plastic sleeve are both tools. The ring is to make sure that you get the seal pressed in the correct distance and the plastic sleeve is to slide it over the crank without damaging the seal lip.
Old Mar 18, 2010 | 02:08 AM
Ok that is back together now on to wake this thing up! Thanks for the help!
dango
Jun 21, 2016 01:13 PM
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
