Dually Mpgs and Mods
Old Mar 15, 2010 | 04:16 PM
shvlhead78's Avatar
Default Dually Mpgs and Mods
Curious to some of the mods that are being used to obtain
good Mpgs on the 7.3l crew cab long bed duallys.
I seem to only acheive 15mpg at best and around 10mpg or 11mpg when towing 5500 pounds. With the mods i have. Working on getting an exhaust system as i post this.
Old Mar 15, 2010 | 04:37 PM
bobcat67's Avatar
ditch the hypertech, get something a little better like a TS Performance 6 position chip or something a little more made for the PSD, exhaust will help too, but remember you are pushing a big heavy pickup with a big engine and nowhere does it say which transmission you have, cause auto vs manual makes a big difference and gear ratio also plays a big role
Old Mar 15, 2010 | 04:49 PM
7.3stroker's Avatar
4in down pipe to whatever you want, and intake make big difference. A custom tuned 6 position chip is your best bet. Make sure you watch your egts if you get a high hp setting. If so get a pyro gauge.
Old Mar 15, 2010 | 04:59 PM
CSIPSD's Avatar
A good chip with an econo tune and an exhaust intake set up will do worlds...
I dont see gauges mentioned... a pyro is a must have...
Talk to Bill and Corey at Power Hungry Performance, they can get you set up with a chip!!!
Old Mar 15, 2010 | 09:32 PM
shvlhead78's Avatar
I have an automatic trans 4r100 i would think. And no gauges just looking for moderate Mpgs and nothing really wild with hp. 4.10's in the rear . Already have the tymar setup.
Old Mar 15, 2010 | 10:20 PM
CSIPSD's Avatar
Does not matter... Stock should have at least a pyro...
Get a pyro, 4" turbo back and a chip... If your not looking to add anymore gauges then just get a 40hp-60hp and 80hp set up.
The 80hp from PHP will put down more total HP then the hypermax on 120 with better MPG and less smoke.
