Boost Increase Valve
Old Sep 3, 2007 | 04:23 PM
DIRTYMAX2004's Avatar
Default Boost Increase Valve
is this a good idea for a stock truck??
http://discountpowerparts.com/catalo...roducts_id=471
Old Sep 3, 2007 | 05:03 PM
Whit's Avatar
Site Mascot
hang on we have a dude that can answer this
Old Sep 3, 2007 | 05:14 PM
DangerousDuramax's Avatar
Actually yes it is. Increasing boost not only increases burn efficiency but helps to reduce EGT's. Thats why trucks with twins seem to last a lot longer at the track than those with singles. They can make high HP levels with low EGT's. Your stock Duramax turbo is good to about 32psi. Anything after that is usless and has no benefit. PPE makes good products for the DMax and have been race and daily driver proven. This mod is safe for your truck and you'll LOVE the added benefits.
Old Sep 3, 2007 | 05:28 PM
do i need to get this at the same time
Old Sep 3, 2007 | 05:37 PM
If you dont have a programmer such the PPE or Predator then yes. It not only will keep from setting codes but you can also control boost.
Old Sep 3, 2007 | 05:54 PM
Whit's Avatar
Site Mascot
wouldnt he be better off with an entry level box so he can get all that plus a few ponies?
Old Sep 3, 2007 | 06:29 PM
Yes you would be better off with a programmer such as in this.....
http://dieseldawgs.com/product_info....oducts_id=3029
Or
http://dieseldawgs.com/product_info....oducts_id=3104
Old Sep 3, 2007 | 06:46 PM
Yes and no. The increase in boost will give him the equivalent of one level on a typical programmer. So, if he buys one such as the Edge he would have to run it on 2 instead of 3 or his stock tranny will limp. The programmer will allow him to make the ECM ignore the codes but he wont have control over boost. It just depends on what he wants to do in the future.
Or
Yeppers...
Old Sep 3, 2007 | 08:02 PM
i want BIG power in the future.
i still need gauges, exhaust and intake though. i want an icebox but they say they dont have them for the duramax yet but i know they do. where do i find one??. i want digital gauges but i havent found any i like. i want them to be back lit in with red or blue. i want boost and egt for sure. havent decided on the exhaust yet though
Last edited by DIRTYMAX2004; Sep 3, 2007 at 08:02 PM. Reason: Automerged Doublepost
Old Sep 3, 2007 | 08:18 PM
Big power takes BIG money. Ya want to run with the big dogs your going to spend $25-30K. Your tranny is going to have to be one of the first mods you do because stock wont hold more than 400hp without limping.
As far as the intake goes the stock Duramax intake is already optimal and cannot be improved upon for air flow. You can install the Cold Air Intake mod to help cool the intake air down but you cant improve the flow. TXChristopher of coolmyduramax has developed a low cost CAI to add to the stock airbox.
If your looking for digital gauges with different color backlight look at the Autometer Nexus series. I'm about to install some on my truck myself. You choose what color or array of colors that the gauges display. They're expensive but the KEWL factor is a 10.
