Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
How do I disassemble this landing gear?
Old Mar 14, 2010 | 06:44 PM
Begle1's Avatar
Default How do I disassemble this landing gear?
Mom's horse trailer has a "48000 Binkley Holland" mechanical landing gear on it. Something in it is seized or stuck.
There's only five pieces to it that I can see but it's got me stumped. Inside of the bungs on either side are "nuts" of some kind that have flats for a wrench, and I can turn them around and around but they don't go anywhere. (You can see where I've mangled them up with locking pliers.)
I don't see how I can take it apart to look at it. It looks to me like I have to break the welds on the bungs to take the horizontal shaft out? Then the worm gear or whatever should pull out the top?
Thanks for any help.
Attached Thumbnails How do I disassemble this landing gear?-uti-169.jpg   How do I disassemble this landing gear?-uti-170.jpg   How do I disassemble this landing gear?-uti-172.jpg   How do I disassemble this landing gear?-uti-171.jpg
Old Mar 14, 2010 | 06:55 PM
ArizonaRedneck's Avatar
it doesnt have a retainer or roll pin in that gear does it or on the backside to keep that gear from moving does it
Old Mar 14, 2010 | 07:09 PM
Begle1's Avatar
The horizontal gear is splined onto the horizontal shaft with a little metal pill of some kind that is pressed into the shaft. On the left hand side in the second picture, on the near side of the shaft you can see the pill.
Around the pill is a heavy metal ring with a notch cut in it to clear the pill; on the left side of the pill and it's metal ring is a ring that looks like a snap-ring only doesn't have a gap in it.
So I can't go to the right with the rod because the horizontal gear hits the vertical gear, and I can't go to the left because the not-a-snap-ring hits the pill. If I could get the pill out somehow I could get it apart...
Old Mar 14, 2010 | 07:21 PM
Spurrit's Avatar
Take a die grinder or angle grinder to that sumbitch.
Old Mar 14, 2010 | 07:40 PM
try this out begle it has the parts layout for your jack SAF-HOLLAND USA > Service > Literature > Landing Gear and then at the bottom of the page click on parts manual and then almost on the bottom of the page is your parts list for your jack
Old Mar 14, 2010 | 08:02 PM
RSWORDS's Avatar
1st step... Clean that bitch off so you can see what your working with. re-greese when done.
Old Mar 14, 2010 | 08:54 PM
Begle1's Avatar
Well, here are the diagrams.
Clean it? CLEAN IT!?!?! Do I look like a woman to you!?!!?
Attached Thumbnails How do I disassemble this landing gear?-48000-1.jpg   How do I disassemble this landing gear?-48000-2.jpg
Old Mar 14, 2010 | 09:05 PM
Spurrit's Avatar
Well, he IS right!
Old Mar 14, 2010 | 09:17 PM
RSWORDS's Avatar
Look like one... No... Act like one sometimes... yep...
Old Mar 14, 2010 | 11:16 PM
Begle1's Avatar
So I like to use tampons on occasion, big deal. I fail to see what that has to do with disassembling a worm gear.
