Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
B2710 axle leak
Old Mar 12, 2010 | 07:42 PM
94dizzyram's Avatar
Default B2710 axle leak
I have a B2710 Kubota tractor with an axle leak. It is leaking right where the drop box enters the upper axle. Where the wheel pivots to turn. Have any of you had this problem or replaced these seals. Just wondering how big a job it is going to be.
Thanks
Old Mar 13, 2010 | 02:36 PM
JKM's Avatar
JKM
Thats a common problem for kubota's, its not a hard job to do, there is also a bushing down inside that is usually worn also, but its a little bigger job if you want to replace that also.
Old Mar 13, 2010 | 03:09 PM
94dizzyram's Avatar
Thanks JKM. how do I get to the seal.
Old Mar 14, 2010 | 07:34 AM
JKM's Avatar
JKM
got a pic of your front axle? the 2710's had two different ones, the newer ones are better as they have an upper bushing also. hard to explain without knowing that one it is.
Old Mar 14, 2010 | 11:57 AM
94dizzyram's Avatar
B2710 axle leak-kubota-front-axle.gif this is a diagram I found online. Thanks for your help.
Old Mar 14, 2010 | 07:45 PM
JKM's Avatar
JKM
There is a steel/rubber plug in the bottom of the gear case (pn 20 in this diagram is the gear case)
pry it out ( which can be fun , you may end up destroying it) Take everything apart in order until you get to the snap ring that holds the gear case onto that elbow, remove snap ring and it should come apart, its not a hard job by any means, just remember what order things came out in, and their orientation. It has been a while since I did one,you may or may not have to remove the big round gear cover & assembly on the side to dis-assemble the unit, some of them you have to access a snap ring though the side, and I cannot remember which ones now.
If you run into troubles PM me and I will give you my phone number.
P.S. - I usually remove the 4 bolts holding the whole assembly on the tractor, remember to drain the oil in the axle and in the gear case(s), And the seals can be fun to pry out once you get to them.
Old Mar 15, 2010 | 06:26 AM
94dizzyram's Avatar
I really appreciate your help. Hopefully I can get the parts ordered this week and get them in by this weekend.
Old Mar 15, 2010 | 08:07 AM
JKM's Avatar
JKM
Not a problem, I used to work on these kubotas, although it has been a few years since i worked on anything but the bigger ones, so my memory is a little foggy on some particulars.
They are notorious for leaking seals, but as long as you dont let them get so bad as to let sand/dirt etc in , the gears and bearings don't usually fail.
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 19, 2014 02:30 PM
Dec 5, 2014 08:30 AM
natenel1
Oct 26, 2014 03:09 AM
