WATER AND METH INJECTION HELP S WHAT ??
Old Mar 11, 2010 | 12:17 AM
MUSCLE1's Avatar
Default WATER AND METH INJECTION HELP S WHAT ??
CAN IT HELP WITH MPG ? CAN YOU PUSH YOUR TIMING? HOW DOES IT HELP? ANY INPUT WILL HELP THANKS
Old Mar 11, 2010 | 06:51 AM
dangerous1965's Avatar
It can help MPG depending on how much meth you use. The main reason it is run is to lower exhuast temps when towing. I've heard a 60/40 mix of meth/water can give you an extra 90 hp!
Old Mar 11, 2010 | 07:04 AM
mfolsomblueD's Avatar
Oh ya with a good mix it can add up to 90 for sure on a dyno run and it seams to help cool but not as much as i assumed it would when i ran it JMO
Old Mar 11, 2010 | 07:44 AM
NadirPoint's Avatar
It also creates an "effect" of timing advance.
Old Mar 12, 2010 | 10:35 AM
cummins bronco's Avatar
i found it made a huge reduction in my egts when towing on my powerstroke.
but it was non intercooled and i ran straight water when towing.
