95 cummins tach hook up
Old Mar 7, 2010 | 01:35 PM
golden763's Avatar
Default 95 cummins tach hook up
hello im putting a 95 cummins motor into a chevy truck all i have is the sensor that bolts to the motor above the flywheel now is there anyway to wire a aftermarket tach into that sensor or no? any help would be appriciated
Old Mar 7, 2010 | 01:43 PM
FastCR's Avatar
easiest way to do it is to buy an ispro, autometer, tinytach, or run the chev alt on the cummins.
or get the cummins alt rewound for a tach signal, alternator shops can do it. get it internally regulated while your at it.
Old Mar 7, 2010 | 05:25 PM
markp's Avatar
How is the tach run off of the Chevy alternator?? My 1984 F350 had a Delco single wire alternator.
Old Mar 7, 2010 | 08:36 PM
FastCR's Avatar
I don't know how it works, but that is how the stock 6.5 alt works, and several people have had the cummins alt set up by an alt shop for a tach signal.
Old Mar 12, 2010 | 07:09 PM
Hobbychoppers's Avatar
The stock sensor on the cummins has 3-wires, power (which the PCM supplies either 5 or 8-volts,I can't remember but I know it's not 12) ground, and signal wire. As for the chevy I'm not sure.
Old Mar 12, 2010 | 08:11 PM
mech2161's Avatar
Mag pick up triggered off the four crank bolts.
GM 4 pin HEI module NAPA TP45SB
W= positive lead from the pickup
G= negative lead from the pickup
C= tach lead
B= positive, ign on
Old Mar 12, 2010 | 09:55 PM
FastCR's Avatar
C= tach lead
B= positive, ign on
daaaang that is a BITCHIN idea.
what does one use for a mag pickup?
Old Mar 12, 2010 | 10:18 PM
mech2161's Avatar
Auto Meter 5211 - Auto Meter Replacement Tachometer Probes - Overview - SummitRacing.com
This picture from CompD.
Old Mar 12, 2010 | 11:51 PM
tltruckparts's Avatar
why dont you just use the chevy alternator thats i did. than your tach will work and itll be internally regulated. thats what i did it was easier
Old Mar 13, 2010 | 02:04 AM
mech2161's Avatar
What if you don't want to buy a Chev alt and fab a bracket. With the alt hook up don't you have to do some kind of adjusting to get it to read the right rpm's?
