ts shift master?
Old Mar 7, 2010 | 11:34 AM
cummins army's Avatar
Default ts shift master?
is any one here running one i am looking at buying one but i dont understand what it actually does any info will help thanks
Old Mar 7, 2010 | 07:23 PM
ullrick's Avatar
hey i just installed one for my buddy about three weeks ago. from what i understand (correct me if im wrong anyone) it kinda takes over your computer and determines how it will shift from its own computer. you get a little *** that goes in your truck and you can adjust the firmness
Old Mar 7, 2010 | 07:41 PM
cummins.1.5.3.6.2.4's Avatar
a friend has one and yes it has a 3 position **** and the higher the setting the firmer it shifts... basically it just ups your line pressure so the clutch packs have a geater holding force and the trans shifts firmer and also the best part of having one of these is welll..... u know when you floor it from a roll and the trans downshifts but if feels like it cant find the right gear for a sec (flaring, ive noticed it to be worst at about 35 on a modded truck) this module gets rid of that, just a firm downshift.
im takin my truck in to get the trans built tomorrow and am gonna order one while its in the shop
Last edited by cummins.1.5.3.6.2.4; Mar 7, 2010 at 07:41 PM. Reason: Automerged Doublepost
Old Mar 7, 2010 | 08:32 PM
cerberus60's Avatar
The shift enhancers modify the operation of the TTVA motor to compensate for more fuel at lower than stock APPS readings. They essentially advance the TV pressure at a different rate and starting point than the stock program, the exact same the kickdown cable on the earlier trucks did.
They do NOT modify line pressure.
They do NOT modify gov pressure.
They do NOT take over any computer functions.
IF one intends to remove the TQ management with a programmer then they are a needed investment. If ones is trying to cure shuttle shift either up or down, hang shifting at WOT, etc, then all it will do is cover up the real cause until it eats the trans.
Old Mar 8, 2010 | 07:20 PM
thank for the info i just got back from the tranny shop and it turned out that the bands on the tranny were way out of adjustment from what the guy told me it took 3 full turns to get them in spec and tighten them down so i am just going to stay away from the shiftmaster seems like it will band aid the problem and make it worse in the long run
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
pappyscrapster
Feb 18, 2015 09:44 AM
TurboBoy6.5
Dec 7, 2014 07:13 PM
