Sway bar end links for dodge!
Old Mar 6, 2010 | 09:17 PM
silvercummins06's Avatar
Default Sway bar end links for dodge!
Hey guys I was just wonding what ya'll think about the new Sway Bar End Links (Dodge) from Tuff Country. Heres the write up on it and if anyone one has this set up I would like some feed back because I'm looking to replace mine there bent.
Sway Bar End Links (Dodge) - Tuff Country EZ-Ride
Don't Leave the Road Without this Suspension Upgrade!!
Tuff Country EZ-Ride Suspension's Dodge Ram Front Sway Bar End Links are for those wanting to upgrade their factory end links. These simple to install replacement end links replace front factory end links by mounting to existing holes. Heim joints are used on the top and bottom to allow more flex and reduce binding. Great for off-roading or just to replace broken or bent factory end links.
Will fit with All Tuff Country Lift Kits
Heim Joints for more flex and less binding
Simple Installation
Replace factory front sway bar end links
Note: Designed to fit Dodge Ram trucks with 0" to 3" of front suspension lift along with ALL Tuff Country lift kits 2" to 6". Will also fit with other manufactures 4" to 6" lift kits that are using an upper sway bar drop brackets.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Sep 14, 2015 06:10 PM
carid
Diesel Bombers Sponsors
Sep 2, 2015 06:56 AM
2FordStrokers
Jan 11, 2015 09:40 PM
