Diesels On The Dyno Diesel Discussions of Dynoing , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST EVENTS IN THIS SECTION*
Almost there but not quite
Old Mar 6, 2010 | 05:27 PM
94 12valve's Avatar
Default Almost there but not quite
Hit the rollers again today at mid atlantic diesel ( thanks Lloyd) to see where I was at. I would like to hit 600 rwhp and I think I have the set up to do it, i just need to work out the bugs.
As of now here is what I have
SDX 5x16's set @ 280 bar
Scheid diesel 12mm 911 pump set at 550cc
timing at 30*
PDI's t4 manifold
Ported and polished head
HD cams big stick, pushrods, and valve springs
air dogg 150
ED's modded s465
I made 3 pulls each with a different plate setting. My first pull was set at 450cc's ( 545hp, 1013 torque), second at 500cc (572hp, 1077 torque), and last was 550cc( 585, 1102 torque).
My dyno sheets are all below and I will post a vid later. I would like some opinions on the hp curve. It fuels hard till 2800 then flat lines but holds the power for another 600 rpm till lloyd let off. I'm thinking my afc may be leaking or has a small hole in it?
here are the sheets, video is comming soon
Attached Thumbnails Almost there but not quite-dyno4.jpg   Almost there but not quite-dyno5.jpg   Almost there but not quite-dyno6.jpg
Old Mar 7, 2010 | 12:28 AM
biged681985's Avatar
nice numbers dave ur not far from 600. as far as your torque curve, idk much about it, and cant see it very good. good luck the next time u hit the rollers to get 6**
Old Mar 7, 2010 | 08:05 AM
94 12valve's Avatar
Thanks
here is the video of the 585 run, that ED turbo sounds sweet
YouTube - Dave Swank
Old Mar 7, 2010 | 10:13 AM
830cummins410's Avatar
nice!!!
Old Mar 7, 2010 | 04:11 PM
94 12valve's Avatar
here is the video of the 572 run
Old Mar 7, 2010 | 08:35 PM
Shea@L&N Performance's Avatar
FormerVendor
whats the specs on the s465?
Old Mar 7, 2010 | 10:49 PM
Farmboy 2.0's Avatar
Nice runs man
Old Mar 8, 2010 | 05:59 AM
94 12valve's Avatar
2.6 inlet the compressor wheel is 99mm on the big side, T4 exhaust housing, and the 74/83 turbine wheel
