need help 03 cummins wont start
Old Mar 1, 2010 | 11:12 PM
ELgoat's Avatar
Default need help 03 cummins wont start
my poor old dad was on his way and stoped to get fuel and truck wood not start he had it towed to a shop and 3weeks and $2500 later the truck stil wont start. so I went and trailerd the truck home.the shop put in new lift pump and main pump, filter on and on and on I started looking at it and shot some WD40 in the intake fired right up and ran fine shut it off and it wont start only with a shot of WD will it start.in my looking I found that the wires to the fan clutch where cut off so i R+R the fan clutch. but still wont start and it is not spitting codes. help!!!!!!!
Old Mar 2, 2010 | 08:06 AM
dieseldude03's Avatar
Likely you have an injector(s) leaking down. Will start and run fine if using ether (starting fluid) or other combustible, i.e. WD-40, but will hard start or not start at all after shutting it down. Most no-start issues with the '03's can be traced to this. Can you smell fuel in the oil or has the oil level risen?
BTW. It is a monstrously bad idea to use ether and other such fluids while trying to start your Dad's truck. The grid heater, located at the bottom in the intake elbow, can ignite these and cause a hell of a boom, possibly injuring both yourself and the truck (a blown-up inter-cooler replacement will run you $1500.00. You eyes and hands will cost a bit more).
Old Mar 2, 2010 | 08:40 AM
ELgoat's Avatar
Thanks for the repley.no chang in engine oil and letting the the heater shut off be for hitting it with WD40.I read a post that fan clutch wint bad and he unpluged the fan and it wood start but sumtimes the ECM wood be effected.
Old Mar 2, 2010 | 09:20 PM
Diesel Nut's Avatar
When it fired up on WD40 did the exhaust produce a lot of white smoke? If so, I am going to say at least 1 injector is stuck open and thus you can't produce any rail pressure, and the truck can't start.
Old Mar 2, 2010 | 09:36 PM
ELgoat's Avatar
no exses white smoke.and I checked for fuel at the fuel rail releaf.thanks for the help.
Old Mar 2, 2010 | 11:06 PM
Diesel Nut's Avatar
That simply means the relief valve has not failed. A failed injector will still bleed off rail pressure. You need to get something that will let you read rail pressure to see if rail pressure is building.
Any chance the wires for the cam or crank sensor were damaged as well?
Old Mar 3, 2010 | 06:58 AM
ELgoat's Avatar
swoped both cam and cranck sinsers out of difrent truck all good. I will check psi but wood that show a coad? thanks for the help
Old Mar 3, 2010 | 09:58 AM
Diesel Nut's Avatar
Not necessarily.
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
Rusher48
Feb 20, 2015 05:19 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
