Rear Main Seal
Old Aug 30, 2007 | 09:54 AM
cloker12's Avatar
Default Rear Main Seal
This coming week I am going to have my nv 4500 rebuilt and a new clutch put in at the same time.
My question is if the flywheel looks ok and the rear main seal isn't leaking should I just leave it alone or should it be replaced also?
Old Aug 30, 2007 | 10:24 AM
Whit's Avatar
Site Mascot
replace the rear main seal no questions asked........also I would replce the pilot bearing and throw out bearing for the clutch too.....they are cheap and you are in there man
Old Aug 30, 2007 | 12:30 PM
cloker12's Avatar
I will absolutly replace the to and pilot brgs but--- I wasn't sure what type of a job the rear main seal is.
I have replaced them on gas engines that where not leaking and wouldn't you know it after I got done the #!!@*& rear main seal started leaking.
Old Aug 30, 2007 | 03:40 PM
Whit's Avatar
Site Mascot
one other tip would be to go get the seal from Cummins or Mopar is the same thing.......dont go with the after market seals.........thats one place I will never go after market....they are cheaper built
Old Aug 30, 2007 | 10:44 PM
toy4xchris's Avatar
dont bother dealing with mopar cummins is usually cheaper for every other part but I would change it so you dont have to go through all this stuff later on that would suck.
Old Aug 31, 2007 | 09:20 AM
cloker12's Avatar
Thanks for the help, and I will check with Cummins on the rear main seal and see what kind of price they have.
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
Max713
Apr 17, 2015 01:20 AM
wildbill
Jan 31, 2015 11:14 AM
