2004.5 dodge 6speed cranks wont start
Old Mar 1, 2010 | 12:06 AM
392hemix's Avatar
Default 2004.5 dodge 6speed cranks wont start
After driving my truck all weekend putting over 400miles on it, i was on the trip home when an hour into the drive the truck skipped, then sputterd and the engine light came on, i drove about 20 minutes to get through boston, i could not go over 2000rpm without a sputter and loss of power. it seemed to start getting better and come out of it when it sputterd from 55 to 30 and i pulled it over and it stalled, i checked for leaks, fuel filter was clean. i have a half tank that was treated when i fueled it with the power service. but now the truck will not start! it just cranks over. Im going to get the codes tomorrow around noon. just want to get this out here so i can get some ideas of what this might be. the trucks only got 53000 on it and has a straight pipe and airaid intake, as far as i know there has never been a tune on it and its stock! please help i need this truck for tuesday!!!!!!!!!!!!
Old Mar 1, 2010 | 12:46 AM
ltr450's Avatar
maybe the lift pump died
Old Mar 1, 2010 | 06:33 AM
cummins_guy's Avatar
x2
Old Mar 1, 2010 | 09:04 AM
392hemix's Avatar
ya, im going to pull the codes around lunch time, im hopeing for that, seems strange to me that it went with so little miles, my 12 valve has 14000 with no issues stock lift pump pushing way more fuel than stock
Old Mar 1, 2010 | 09:24 AM
mfolsomblueD's Avatar
i think p0268 and others will let you know that its the lift pump
Old Mar 1, 2010 | 03:11 PM
392hemix's Avatar
PO628 -Low vlotage at the lift pump
PO148- High PSI Common rail checksum
PO107- inlet air temp low
PO73- ambient temp sensore to high
PO88- fuel psi to high
These are the codes, i had it towed to the dealer, for it to be fixed under warrenty. the lift pump is back ordered.......so i was thinking about a fass or air dog.
Old Mar 1, 2010 | 06:42 PM
zach_west's Avatar
i'm guessing you checked fuses and relays 2. but ya sounds like a lift pump 2 me 2.
Old Mar 1, 2010 | 06:47 PM
Red_Rattler's Avatar
High Tech Redneck
Lift pump for sure i burned through 2... AirDog
Old Mar 1, 2010 | 07:49 PM
392hemix's Avatar
airdog is most likely in order once funs are deposited into bank.....599 here i come thank u guys for the info!
Rusher48
Jul 2, 2020 08:39 AM
Mac1997
Jul 13, 2015 05:08 AM
Strangeak
Jun 19, 2015 11:07 AM
rschriek
Jan 26, 2015 07:30 AM
Tyler_302
Oct 22, 2014 07:08 PM
