92 d250 (wait to start light stays on)
Old Feb 25, 2010 | 02:42 AM
reddpup's Avatar
Default 92 d250 (wait to start light stays on)
I just bought a 92 d250 and I have a few problems with it.The wait to start light quit working when you turn the key on but after you start the engine it comes on and stays on.Engine starts and runs perfect.Not sure what would cause this.I also dont have a check engine light when the key is turned.I was wanting to see if I had any codes but there is no light to flash,I have not pulled the dash out yet to check the bulb.All fuses are good.My overdrive is not working either.Anybody know where the pcm is on these trucks?Any help would be appreciated.Thanks John
Old Feb 25, 2010 | 07:54 AM
Budgreen's Avatar
sounds like a PCM problem, or a wiring problem.
first step would be to check the body ground right by the battery terminal.
Old Feb 25, 2010 | 11:46 AM
reddpup's Avatar
Default wait to start light
Ok where is the pcm at on these?I will check the grounds first before I start replacing parts is there a way to check it?Can it be scanned at auto zone?
Old Feb 25, 2010 | 11:57 AM
tltruckparts's Avatar
the reason why the lights stay on on these is if the computer is signalling too high of voltage or way too low of voltage. most likely you got a computer issue. but ive also seen this happen when one of the intake heater elements goes bad as well. also check the ground the goes from the intake heater to the ground on the housing. i dont remember exactly where the pcm is but iirc its on the driver side fender well
Old Feb 25, 2010 | 01:43 PM
Budgreen's Avatar
oh, and there's a whole 6? sensors on the whole truck... no need for scanning, and i'm pretty sure there is nothing to be scanned anyways.
Old Feb 25, 2010 | 02:51 PM
gradyc's Avatar
We have a 92 d350. The pcm is tucked inside the fender behind the battery. I got the dodge factory manual on C.D. from GENO'S Garage. I might be able to send some diagnostics from it to you. I think the C.D. cost us about $30.
Old Feb 25, 2010 | 06:52 PM
reddpup's Avatar
Thanks everybody for the input.This is my first diesel and I am not familiar how everything works.
Old Feb 26, 2010 | 10:37 AM
Diesel Nut's Avatar
Welcome to the slippery slope! You'll never go back to gas.
Old Mar 3, 2010 | 11:27 PM
2500HeavyDuty's Avatar
updates?
Old Mar 4, 2010 | 04:46 AM
reddpup's Avatar
truck is still at transmission shop no speedo or overdrive.getting new speedo gear next week mine was wore out hope to get it back next week so I can diagnose the problem with wait to start light.I just bought the truck it worked fine the day I picked it up but now its doing what I described above.
schwier94
Sep 26, 2016 09:07 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
bullrideris1
Jan 23, 2015 09:22 AM
NCC74656
Nov 4, 2014 10:46 AM
