7.3 no start when cold
Old Feb 23, 2010 | 07:27 PM
gsfloor's Avatar
Default 7.3 no start when cold
Hey Everybody just bought a 1989 ford with 7.3 from original owner out west. got truck wouldnt start just cranked when cold outside temp here about 20. He only had one battery I replaced both batteries with 1000 cranking amps still wont start when cold,replaced glow plugs still wont start,relay is working dont know what else to check I read some other posts but not sure. When I go to first start in morning cranks for about five seconds and sounds like going to kick over but doesnt then just cranks like nothing. Any ideas?
Old Feb 23, 2010 | 07:30 PM
mcdowell's Avatar
try the fuel line make sure there not stoped up and your fuel filter
Old Feb 23, 2010 | 07:32 PM
gsfloor's Avatar
it has a new fuel filter previous owner changed about a month ago what fuel line should I check? once it starts in the morning starts and runs fine for the rest of the day
Old Feb 23, 2010 | 07:45 PM
mcdowell's Avatar
just pull the on on the frame
Old Feb 23, 2010 | 09:17 PM
gradyc's Avatar
Take a wire off one of the glow plugs and check for power there when you first turn the key on. It might have a fuseable link between the relay and glow plugs that has gone bad. Also if you have a block heater keep it plugged in and it should start after sitting long periods.
Old Feb 28, 2010 | 03:02 AM
bajabomber87's Avatar
God those fuseable links are the devil. But its a good place to look for problems.
Old Feb 28, 2010 | 12:24 PM
DieselDanBoy's Avatar
heres a question....
how long does the wait to start light stay on?? it should stay on for about 10 to 20 seconds depending on how cold it is, if the light stays on for that time check for fuseable links from the gp controller to the relay, i know from 94.5 to 97 they're next to the starter relay under the dash. not sure if they're the same..
if the light shuts off immediatly you might need a new controller but you said the relay is switching on so it sounds like the controller's working.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
