Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
oil for kubota tractor
Old Feb 23, 2010 | 05:24 PM
94dizzyram's Avatar
Default oil for kubota tractor
I have a kubota 2710 tracor and am going to change the oil. Can I run my rotella 15w40 in it. Thanks
Old Feb 24, 2010 | 12:33 AM
zach_west's Avatar
I don't see why not we run that in the little john deere tractors at work and I've never seen a problem with any of it.
Old Feb 24, 2010 | 04:09 PM
94dizzyram's Avatar
Thanks, I just wasnt sure if kubota called for one particular oil. I guess I would run rotella even if they did.
Old Feb 24, 2010 | 11:23 PM
Kirk T's Avatar
Default Former Diesel Mechanic
As Service Manager for a large equipment rental company for 15 years, I have used Shell Rotella T, Mobile Delvac, and Chevron Delo 400. All equipment (including Kubota)was tested with scheduled oil sampling, and the results were the same. The only oil that I know of that will screw with a sample is Penzoil due to a high copper content. If this oil is known during the SOS, then it does not even it show a problem. In short, use a well-known brand that is Diesel rated. You will be OK.
Old Feb 26, 2010 | 06:23 PM
94dizzyram's Avatar
thanks kirk
Old May 8, 2010 | 01:47 PM
country_boy's Avatar
i used to be a mechanic at a kubota dealership and all we used in the diesels was 15-40 thats what i even run in my G1800
Old May 8, 2010 | 02:02 PM
12vcummins96's Avatar
i run delo 15w40 in mine
Old Jul 19, 2012 | 01:12 PM
Carguy3406's Avatar
You can run pretty much any brand oil you like. Depending on the engine (and year), the service manuals typically call for a CD grade oil. The weight of the oil is climate dependant, but 15-40 has always been a good standby
vin_diesel
Mar 1, 2016 01:43 PM
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
